Old 10-24-2023, 09:50 PM #1
SocalSam SocalSam is offline
SocalSam will become famous soon enough
JBL Sub-Woofer Replacement Suggestions
Sub-woofer in my new to me T4R is blown. What driver are you guys using for replacement?
SocalSam is offline   Reply With QuoteReply With Quote
Old 10-25-2023, 04:18 PM #2
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
There's a few threads out there if you search subwoofer within this forum. I think I recall people installing Pioneer. You could also go to Crutchfield and punch in your car info. These seem to fit mine, may be the same for yours.
8 Inch Subwoofers at Crutchfield
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 10-27-2023, 11:18 AM #3
twa318 twa318 is offline
twa318 is on a distinguished road
I went with the Kenwood XR but honestly if I had to do it again I would have gone with the cheap amazon sub instead, you're really not going to get much out of an 8" in that enclosure.
I also used the lazy hot knife cut instead of removing the whole side panel and its been holding up fine for last 4 years, you cant even tell it was cut out.
'99 SR5, 2007 Sport
twa318 is offline   Reply With QuoteReply With Quote
Old 10-27-2023, 07:06 PM #4
"Hot knife method"? Interesting. I pulled the side panel which should have been easy except for the knob plastic connector. Stock sub is dual coil. Both VC's measured about 7.3 Ohm which I think is good. Surrounds were gone but the driver should have moved with signal. I replaced both head unit and amp with same result. Hmmm.
Old 10-27-2023, 08:42 PM #5
Very easy/lazy method, just take a knife, heat it up, cut out the surround. I used a folding husky box cutter knife with a fresh blade.
With a clean cut the mesh surround just pops right back in. A few forum threads detail the process.
Downside is you lose protection for the sub from objects being thrown around in the cargo area but I keep a ton of crap back there and never had an issue. Also easy access in case sub goes out again in the future.
'99 SR5, 2007 Sport
Old 10-27-2023, 09:08 PM #6
0verland's Avatar
0verland 0verland is offline
0verland will become famous soon enough 0verland will become famous soon enough
0verland's Avatar
I went with a Rockford Fosgate P3SD2-8 when mine blew. I have no complaints what so ever about it. Great little sub with good lows, mids and highs for just the right price.
2006 V8 Limited 4WD
| Doug Thorley Headers | Gibson | Old Man Emu | ToyTec | SPC Performance | RCI Metalworks |
| Skid Mark 4x4 | SpiderTrax | BFGoodrich KO2 | aFe | Rutech | HCF Mod |
0verland is offline   Reply With QuoteReply With Quote
Old 10-27-2023, 10:25 PM #7
Oooh. I just looked at photos. It's 2 Ohm rated so a tough load for amplifier. Can our stock amp handle this? And what about mounting? I see four mounting holes in the sub photo while our sub box has six.
Old 10-27-2023, 10:29 PM #8
The sub-panel that covers the sub is in theory removable but it has a hot weld in the back to hold it in place. (This sub-panel does not have a grill opening for non-JBL optioned trucks.) If this panel can be made to open on demand, that would give plenty of access to the sub cover. It would look totally stock and not compromise protection.
Old 10-31-2023, 03:15 PM #9
Thanks for the replies. I ordered Pioneer TS-A2000LD2 from Amazon, $65 shipped, includes $60 coupon for signing up for Amazon Shop card. This sub has 6 screw mount so easy install. I cut out the plastic welds for the sub cover. Cover pops back into place and is friction held but the mounting posts. Not ideal but it stays in place.
Old 10-31-2023, 06:48 PM #10
benostler33 benostler33 is offline
benostler33 is on a distinguished road
I bought a Pioneer TS-2000LD2. I understand why it's a popular sub but it just doesn't do the job for me. I'll replace that one a little while down the line
benostler33 is offline   Reply With QuoteReply With Quote
Old 10-31-2023, 08:27 PM #11
What did you not like? Did it sound like the stock woofer, which I have never heard. I'm not looking for a competition sub. I just want the rear channel to sound normal-ish, whatever that is.
Old 10-31-2023, 09:15 PM #12
I never heard my stock sub because it was blown when I bought the car. Don't get me wrong, it's a good sub, but it is not what I was specifically looking for (because i'm an audiophile lol). I listen to rap music, and this sub doesn't play the low bass very good. Everything else it's perfectly fine.
Old 10-31-2023, 10:38 PM #13
I don't think any rap fan rocks an 8 inch sub. I went to a stereo installation shop to see if they had something off the shelf and they laughed at me. Anyways, based on your other words, I think the Pio will be fine.
Old 11-01-2023, 06:20 PM #14
Yep, that's my next move lol. I thought that's all I needed to do because my other car (2009 mercury mariner) has the single greatest factory sound system of all time. Haven't been in/driven a car with a better factory sub
Old 11-03-2023, 04:44 PM #15
cdoyle's Avatar
cdoyle cdoyle is offline
cdoyle is on a distinguished road
cdoyle's Avatar
What are you hoping for with the replacement? Are you going to replace the factory amp too?
When my sub blew, I decided to redo the entire system. I went with a Fosgate
T1 10inch. Running off of a Fosgate T1000x5. Made my own enclosure for it and I cannot believe how much better this sounds. I was totally impressed that it performs the way it does.
Been in there 2 years now, working great.
More images in the link in my sig of the system as I was putting it together.
Check out my 2004 4Runner Audio upgrade.
cdoyle is offline   Reply With QuoteReply With Quote
blown , guys , jbl , replacement , sub-woofer
Rear woofer replacement, foam, cover, and cabinet questions Seasparrow 4th Gen T4Rs 3 05-03-2019 02:19 PM
Replacement Stereo - Suggestions? alphamikefoxtrot 3rd gen T4Rs 25 07-30-2018 09:50 AM
Sub Woofer Box Install--2015 4Runner (using FJ Cruiser Woofer box) DEERUNNER 5th gen T4Rs 14 09-16-2015 10:14 AM
speaker replacement suggestions fourrunner1 5th gen T4Rs 2 05-02-2014 09:48 PM
