Old 11-01-2023, 07:31 PM #1
TrueNorth4Runner's Avatar
TrueNorth4Runner TrueNorth4Runner is offline
TrueNorth4Runner is on a distinguished road
TPMS Bypass woes in a 2008 - a little help?
I've searched the forum, read the topics, thought I did it right, but seems not...
My TPMS light is blinking, either because I have a 2008 and the batteries in the sensors have given up the ghost, or whatever other reason.
I knew you can bypass it, and I figured now it was time to do so, since I always check my pressure manually anyway (even the spare)
I looked up the wiring, and from everything I read, in my 2008, the correct procedure was to open up the panel, then locate the:
PINK w BLACK stripe wire
BLACK w REDDISH stripe wire
and then use a locking type connector.
I did so, as you can see in the attached photo.
I did that today, this morning.
When I first did it, SUCCESS. The light was gone, I ran the car for 30 seconds to make sure, all was good.
Then I went to run errands this evening, and the light is back. I opened up the panel in the store parking lot, checked everything, seems to be connected, nothing popped out etc
Did I do something wrong? Wrong colours? (I know that the colours are different in the pre 06's, but everyone with an 07-09 said it was the colours that I used)
I want to say that it is the "aftermarket" (non-3M) connector, not splicing through the wire casing, but..... why would it have worked the first time I ran the car after doing it?
Any pointers would be appreciated, things like this drive me insane. It should have worked.
I hope there is an easy solution!
Thanks again!
TPMS Bypass woes in a  2008 - a little help?-20231101_190255-jpg
2008 4Runner SR5 - Bone Stock for now!
TrueNorth4Runner is offline   Reply With QuoteReply With Quote
Old 11-01-2023, 09:33 PM #2
d33pt d33pt is offline
d33pt is on a distinguished road
I bet you it's just the connector. Those really suck. I just jumped the PIN in the harness.
d33pt is offline   Reply With QuoteReply With Quote
Old 11-01-2023, 10:11 PM #3
Gotcha, noted. So just a matter of physically connecting them, rather than relying on a crappy connector.
I did want to confirm, those ARE THE CORRECT coloured wires for my 2008, though, right?
I am supposed to be connecting those to one another.
Old 11-02-2023, 02:56 AM #4
That's actually the wrong colors too. It's PINK-BLACK (TPMS) and WHITE-BLACK (Ground). You're basically grounding out the TMPS wire.
Old 11-02-2023, 08:12 AM #5
See, that's where I'm torn. I've searched many threads, and it seems that:
2003-2006(ish) - PINK/BLACK and WHITE/BLACK
2007-2009 - PINK/BLACK and BLACK/RED
I don't even have a white wire with a black stripe, in my loom. Also, the earlier years had the Orange TPMS module, while the later years (like mine), had the Grey module.
That's why I am hoping someone else can pipe in and confirm, because otherwise you and I will be going back and forth on this colour thing!
Let's hope we can confirm this!
Old 11-02-2023, 10:27 AM #6
J.A.'s Avatar
J.A. J.A. is offline
J.A. will become famous soon enough
J.A.'s Avatar
You are correct that the 2008-2009 models had a TPMS change (see attached).
These models also do not have the Ground wire (White-Black) at #11. Rather, I believe, they have the Ground wire at #9 and it is solid Brown.
Although I have not confirmed this, I would try to connect your Pink-Black wire at the #5 position (was #6 in 2003-2007) to this Brown #9 Ground wire.
FYI, for those with 2003-2007 here is the TPMS bypass mod in detail as i recently performed it...Toyota 4Runner Tire Pressure Monitoring System (TPMS) Disable Mod
If you confirm this works, I will add this change in process for 2008-2009 models to my write up documentation. Just let me know.
Hope that helps, best of luck.
TPMS Bypass woes in a  2008 - a little help?-2008tpms-change-jpg
J.A. is offline   Reply With QuoteReply With Quote
Old 11-02-2023, 10:45 AM #7
Forum148 Forum148 is offline
Forum148 is on a distinguished road
This is the way I did mine. Super easy and reversible. I know whatís done is done in your circumstance. But could be worth a try as well.
https://www.toyota-4runner.org/3350475-post13.html
06 V8 SR5 --Kings--JBAs--RCI armor--Lil B's--33s--Wheel and Party--
Forum148 is offline   Reply With QuoteReply With Quote
Old 11-02-2023, 12:16 PM #8
Syr4RinNC's Avatar
Syr4RinNC's Avatar
I think youve got the wires correct to jump.
Ive had issues with those splicers before too. Id carefully open it up. Make sure the wire covering have a nick so you can see copper. really wedge the wires down into the metal bridge so they both have good contact with it. you may want to put some electrical tape in too to hold the wires down, then lock it back up
Old 11-02-2023, 05:54 PM #9
thegame7 thegame7 is offline
thegame7 is just really nice thegame7 is just really nice thegame7 is just really nice thegame7 is just really nice
My solution: Pull the TPMS light in the dash and install new regular valve stems. Won't ever have to deal with that system again
2007 Sport Edition V8 4WD w/Nav, JBL and rear seat entertainment, Fox 2.5 R/R coilovers, FJC rear springs with Fox 2.0 Pro series shocks, Rear ARB locker, 305/70R17 Ridge Grapplers, DT short headers
thegame7 is offline   Reply With QuoteReply With Quote
Old 11-02-2023, 09:46 PM #10
Hahha If removing the dash was ALSO just one single bolt? Absolutely !
Otherwise, I may still try to fiddle with the wiring ;)
Old 11-02-2023, 09:48 PM #11
All else fails, I'll give that a whirl, but I feel it may just be the crappy connector/splicing job
Old 11-02-2023, 09:49 PM #12
This also seems to be my suspicion. The connector doesn't look like it would really cut through the casing well. I am curious if maybe I needed either the "smaller size down" one (this was the 14 to 18ga), or .... assuming I have the correct wires, I just splice in and manually connect them
I am 99.9999 % I have the right coloured wires, but man... it should be working then!
Old 11-02-2023, 11:52 PM #13
Definitely not 1 bolt lol. I struggle with wiring 99% of the time, way more of a mechanical dude
Old 11-03-2023, 08:09 AM #14
Same. Ask me to change a CV axle or suspension, and I'm ready to go. Ask me to figure out a wiring gremlin, and I'm bringing out the bourbon.
colours , light , time , tpms , wire
2008 TPMS bypass Toyota Jim 4th Gen T4Rs 25 03-03-2021 11:25 PM
5th gen TPMS Bypass help ABDave 5th gen T4Rs 19 12-28-2020 02:34 AM
TPMS woes... Shamish 5th gen T4Rs 5 10-28-2019 06:09 PM
TPMS Bypass for 5th gens. hearno 5th gen T4Rs 45 08-02-2018 08:40 PM
TPMS Woes.... Jerm 4th Gen T4Rs 10 03-26-2015 08:54 AM
