Old 11-03-2023, 03:48 PM #1
tysauce's Avatar
tysauce tysauce is offline
tysauce is on a distinguished road
tysauce's Avatar
Help with Alignment after Lift
I'm sure this topic has been beat to death, but wanted to hear some advice. I recently had 5100s and OME 885 front springs and 895 rear springs installed. Provides a 2.5-inch front lift and 1.5-inch rear lift. Also installed new 275/70/17 tires.
I had them install new UCAs and LCAs, though they are NOT aftermarket, just replaced with stock, non-rusted, options.
It was installed at a 4x4 shop and when they were done, they completed an alignment. The tech said he got it as close as he could within spec while also trying to save on the handling. He did note the camber was a little off so I might notice some slight premature wear on the outer edge of the front tires, but said it was small enough to not be a concern with normal rotations.
After the lift has settled over the last couple months and 500+ miles I took my 4Runner back to the shop to have them perform a complimentary look over/re-torque/test drive to make sure everything was still good to go. I thought maybe they would realign it now that it settled to bring the camber in, but they said all was well and looked good.
I guess my question is, do these alignment specs seem okay?
Help with Alignment after Lift-alignment-jpg
2007 Sport Edition 4wd V8 - Titanium Metallic // 5100s with OME 885/895 2.5/1.5 lift // 275/70/17 General Grabber atx // Spidertrax // Magnaflow 18" // Both VSC-Trac off mods // HCF Delete // Plasti-dip emblems and grill // Window Tint
tysauce is offline   Reply With QuoteReply With Quote
Old 11-03-2023, 06:37 PM #2
Forum148 Forum148 is offline
Forum148 is on a distinguished road
My guess and I'm no alignment pro is that the truck probably drives fine. What I'm concerned about would be the camber numbers which ultimately will wear your tires unevenly. And the castor numbers being that low (won't effect tire wear). As long as nothing is bent like the spindles then those numbers should be able to be closer to zero. Also the alignment machine highlighting those as "red" are calling them out as being out of spec.
06 V8 SR5 --Kings--JBAs--RCI armor--Lil B's--33s--Wheel and Party--
Forum148 is offline   Reply With QuoteReply With Quote
Old 11-03-2023, 07:04 PM #3
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I'd take it to another alignment shop, the caster numbers are off quite a bit.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 11-03-2023, 07:58 PM #4
shiftmx's Avatar
shiftmx shiftmx is offline
shiftmx is on a distinguished road
shiftmx's Avatar
They tried to give you as much "in spec" camber as possible to get you closer to spec on caster. I don't think this is good. If you have a more aggressive tread pattern tire, you will notice the outside tread lugs beginning to feather over time even rotating every 5k. Ask me how I know.
I would bring it back and tell them to set the camber to 0 or -.1 whichever they can get. The caster will be really low and it make take a little more correcting on the highway. You will need aftermarket UCA's to get in spec caster. I've been fighting all of this recently and I just bought a set of freedom offroad UCAs to fix it. I also have less front lift that you.
2007 4runner Sport V6 4wd: 265/65r18 Nitto Ridge Grappler - 18" limited wheels w/1"+ 1.25" spacers - Eibach/TRD lift - Cali Raised sliders - Westcott Designs roof rack
shiftmx is offline   Reply With QuoteReply With Quote
Old 11-03-2023, 11:07 PM #5
tysauce's Avatar
tysauce's Avatar
Appreciate you all! Gonna get another alignment and let them know what I want. Glad I asked.
Old 11-03-2023, 11:13 PM #6
inscarguy's Avatar
inscarguy inscarguy is offline
Real Name: brian
inscarguy has a spectacular aura about inscarguy has a spectacular aura about
inscarguy's Avatar
Real Name: brian
What is concerning to me is your rear toe. Granted the rear is not adjustable but tor left wheel has negative toe (pointing out) and the right wheel is pointing in ( positive toe). Basically you are having rear steer to the left and they are way off. I would check your bushings, track bar, control arms, diff housing. Something is bent bad.
Here is what I learned when doing alignments:
"All wheels are adjusted to the center of the vehicle by measuring the rear axle positioning first followed by the measuring of the front angles. This ensures that your vehicle is centered accurately.
The rear-end alignment is a more precise, accurate, and true to vehicle specifications process than the front-end alignment."
If your rear is not right, your front won't be.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
inscarguy is offline   Reply With QuoteReply With Quote
Old 11-04-2023, 12:12 AM #7
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
There's not much room for caster adjustment via lca's with that much lift. With the proper upper control arms this will correct your castor. Actually if you've lifted correctly you shouldn't even have to touch the lca alignment tabs. Toe is all you should need to adjust.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 11-04-2023, 08:33 AM #8
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
you can tell them nicely to get the caster to 3.
I have 5100 at 0.85 and moog fj springs, stock upper and lower control arms.
I tell them to get the caster to 3 and my final number is 3.1 and 3.3.
my last alignment was 3.0 and 2.9, also before all the inner and outer tie rod ends replaced along with new cv axels. truck still drove fine, but it also wander sometimes due to worn parts, I had 221k at the time. which was 2 - 3 months ago.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
alignment , front , installed , lift , rear
Alignment help after lift 4runnerfiend 5th gen T4Rs 1 06-18-2020 10:54 PM
Why You Should Get an Alignment After Lift RPC General Discussions 3 04-29-2018 12:58 AM
lift with alignment rnb754 5th gen T4Rs 3 07-26-2014 05:17 AM
Alignment after lift glock56534 Engines / Suspension / Wheels / Tires / Audio / Accessories 6 01-17-2011 08:55 PM
Alignment after lift snow&surf 5th gen T4Rs 2 09-04-2010 02:05 PM
