Old 11-05-2023, 08:49 PM #1
Byways Byways is offline
Byways is on a distinguished road
Oil control valve filters
Have you ever removed, cleaned or replaced the 1GR-FE's two oil control valve filters? I'm anticipating doing so on my 04 & 05 T4Rs and would welcome insights. It seems an important maintenance item.
Byways
http://www.backcountrybyways.com
Byways is offline   Reply With QuoteReply With Quote
Old 11-06-2023, 09:30 AM #2
daprotege5 daprotege5 is offline
daprotege5 will become famous soon enough daprotege5 will become famous soon enough
they just slide in and out with a bolt. i believe their either a 12 or 14mm but once you loosen it, the filter slides out with it.
daprotege5 is offline   Reply With QuoteReply With Quote
Old 11-08-2023, 03:58 PM #3
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
Where are they located and how easy are they to get a wrench on? I have looked but never could find them
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMPhows it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 11-08-2023, 11:24 PM #4
you can see the one by the power steering pump pretty easy, basically a bolt towards the top part of the engine, that goes into the engine, the drivers side one though i believe something restricts the view.
Old 11-09-2023, 08:57 AM #5
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
I've replaced mine and it was necessary, as the engine had been neglected and run for 20k oil change intervals and had some sludge. You'll want to get new crush washers for the cap bolts to ensure a good leak-free seal.
If you've kept up with oil changes and run decent oil, it's unlikely yours are crudded up.
I'd pull the easy one and check it, located passenger side behind the oil dipstick so it's an easy pull. If it's clean, no reason to pull the harder to access driver side filter. If it's got sludge...off you go.
Get a new crush washer and torque the cap bolt to spec as shown in the attached service manual pic.
Oil control valve filters-4runner_ocv_filter-jpg
waypoint is offline   Reply With QuoteReply With Quote
Old 11-09-2023, 09:43 AM #6
zguy1's Avatar
zguy1 zguy1 is offline
zguy1 has a spectacular aura about zguy1 has a spectacular aura about
zguy1's Avatar
I agree with the above. I pulled mine when I did my head gaskets at almost 300k miles. Mine were very clean. Check the passenger side condition and go from there.
zguy1 is offline   Reply With QuoteReply With Quote
Old 11-09-2023, 04:15 PM #7
MikeinNH67's Avatar
MikeinNH67's Avatar
I didn't realize this was a thing. My truck was sludged up when I got it from former owners neglect. I should check into these.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 11-09-2023, 05:09 PM #8
never found them on the original motor that blew, and when i got the new short block, you could clearly see them.
Old 11-09-2023, 08:06 PM #9
Drcoffee's Avatar
Drcoffee's Avatar
Got a picture you can post?
Old 11-09-2023, 08:21 PM #10
here you go, passenger side. when you take the bolt out the whole plastic filter comes out. its almost in exactly the same spot on the other side but i forgot exactly whats blocking access to it.
Oil control valve filters-1-jpeg
Old 11-09-2023, 08:31 PM #11
Drcoffee's Avatar
Drcoffee's Avatar
I found a rusty bolt head above the PS pump under the exhaust. Is this the filter bolt?
Oil control valve filters-img_9831-jpg  Oil control valve filters-img_9832-jpg  Oil control valve filters-img_9836-jpg
Old 11-09-2023, 08:59 PM #12
zguy1's Avatar
zguy1's Avatar
Yes, that's it.
Old 11-10-2023, 03:40 PM #13
Drcoffee's Avatar
Drcoffee's Avatar
Looks easy enough but its not. Getting it back in was a pain in the butt. You have to install it blind and by feel. Dropped the plug twice down to the skid plate. But I confirmed the filter was clean as new. I use mobil1 so I expected that to be the case. Just turned 230k miles.
Hard to believe its 46 lbs/ft. I think that torque spec was for later engines with the banjo bolt. Just verified, That torque spec is correct.
control , filters , maintenance , oil , valve
Bad idle air control valve ?? Traveler74 3rd gen T4Rs 3 10-09-2020 04:31 AM
Heater control valve thegipper 3rd gen T4Rs 13 12-28-2019 02:10 PM
FS:5 04152-YZZA5 Oil filters $25, free Fumoto F103 Oil drain valve, GEN 5, N Dakota kup1236 For Sale: T4R Items 2 05-14-2018 01:21 PM
Idle Air Control Valve ford2774 Classic T4Rs 0 06-28-2007 08:13 AM
