Originally Posted by rumfoord
do you have a center speaker? if so pop off the grill and you may find a circular piece has come loose, glue it back on and put the cover back.
careful with the grill, its a bit fragile, if you have a retainer clip removal tool I would recommend using that at the front of the grill to pop it up.
Good call. I will check it, although my grill is already broken. The main thing I notice is if I hold pressure on the dash, it stops rattling. Maybe this will help.
Thanks!
