Originally Posted by TeryT
Yeah, and there's the rub - I've been under it, as well as a mechanic and an oil tech a number of times over the past 4-5 months, and no one sees nutin!
As mentioned if the maser cylinder is leaking past the piston there would be fluid coming out the back of the master cylinder, you won't find that leak from under the vehicle, you need to look under the dash where the master cylinder push rod connects to the brake pedal, you my have to pull the rubber boot off the back of the master cylinder or not if you losing as mech fluid as you say it maybe leaking past the boot.
