Old 11-14-2023, 09:50 PM #1
cice cice is offline
cice is on a distinguished road
V8 Just Died at a Stoplight...
Hi folks,
I have a 2007 V8 with 238k miles. It still runs like new... except today, while sitting in traffic at a stoplight I looked down and the engine had just stopped. The CEL, battery, and oil lights were all on. I put it in park, turned the key and it fired right back up. No CEL and no pending codes. I've driven it around tonight and it hasn't had any issues. No hesitation, sputtering, or randomly shutting off. Just rock solid like usual. I filled up the tank and added a can of Sea Foam. Any other ideas on what could have caused the random engine stop?
Thanks!
cice is offline   Reply With QuoteReply With Quote
Old 11-14-2023, 10:31 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
No solid ideas, but when last do plugs, timing belt, battery? Check your battery terminals for one being loose.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 11-14-2023, 10:33 PM #3
Excellent suggestions, thank you! Plugs are due at 240k (already have them in the garage). Battery terminals are solid and connected well (had that happen before where they were loose) Timing belt was done about 30k miles ago. Battery is 2-3 years old.. but the engine cranks really hard so I think the battery is fine...
Old 11-14-2023, 10:34 PM #4
It seems... and now I'm biased... to idle lower than it used to. It ideas around 500 - 480 RPM when the A/C compressor isn't running. Could that be the issue? The RPMs dropped too low and the ECU shut off the engine?
Old 11-14-2023, 10:34 PM #5
MrSeth's Avatar
MrSeth MrSeth is offline
Real Name: Seth
MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough
MrSeth's Avatar
Real Name: Seth
I am going to second that you check your serpentine belt AND battery terminals. Sometimes they can wiggle off or just be loose enough to kill it.
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
Last edited by MrSeth; 11-14-2023 at 10:37 PM. Reason: put timing instead of serpentine
MrSeth is offline   Reply With QuoteReply With Quote
Old 11-14-2023, 10:35 PM #6
What do you mean by check the timing belt? It is buried in the engine... Do you mean the serpentine belt?
Old 11-14-2023, 10:37 PM #7
MrSeth's Avatar
Real Name: Seth
MrSeth's Avatar
Real Name: Seth
FSM states 650 to 750 rpm at idle is normal (for reference)
I once had a DIRTY air filter on my V8 and it low idled too. Lost power on acceleration, sputtered etc.. I wonder if its that?
Old 11-14-2023, 10:38 PM #8
MrSeth's Avatar
Real Name: Seth
MrSeth's Avatar
Real Name: Seth
sorry friend, yes, serpentine belt. If they are hard and worn, they can slip a lot leading to your alternator not charging your battery or powering your vehicle as well as it could be.
Old 11-14-2023, 10:45 PM #9
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Ever cleaned your mass air sensor and throttle body?
Old 11-14-2023, 11:08 PM #10
Thanks guys, changed the air filter two weeks ago and also cleaned the MAF. Serpentine belt is a good idea though, and the A/C was cycling so maybe it slipped...
Old 11-15-2023, 11:41 AM #11
Zero0575's Avatar
Zero0575 Zero0575 is offline
Real Name: Casey
Zero0575 will become famous soon enough Zero0575 will become famous soon enough
Zero0575's Avatar
Real Name: Casey
Any chance you have a secondary air pump bypass kit? I had the same issue, eventually giving me rich codes after dying a couple times. Ended up being my secondary air pump bypass went bad. Lifetime warranty replaced for free, and no issues since replacing.
2007 Limited V8 | 275/70/18 Falken Wildpeak AT3W | Spidertrax | 4xInnovations Weld On Sliders | Victory 4x4 Blitz Front Bumper | RCI Skids | TNF Rear Bumper | Smittybuilt Winch | KOYORAD Aluminum Radiator |OME 886 Front/Toytec Superflex HD Rear and OME Shocks/Struts | JBA High Caster UCA | Rebuilt LCA with Superpro bushings + Moog BJ | HCF Delete | Doug Thorley Shorty Headers | Magnaflow HFC | Gibson Catback | Rear Diff Breather Extension | 20" Spot/Flood | 9" Spots | DD SS3 Yellow Fogs | Amber Grill Lights | Fog Lights Anytime Mod
Zero0575 is offline   Reply With QuoteReply With Quote
Old 12-04-2023, 11:52 AM #12
It did it again today. What bypass kit did you have installed? The slyfox one?
Old 12-11-2023, 01:56 PM #13
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Maybe a small vacuum leak?
Perhaps a dying battery also. I had many electronic gremlins when my battery was going.
gaber6 is offline   Reply With QuoteReply With Quote
Old 12-11-2023, 04:25 PM #14
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Clean the throttle body as rdruss suggested.
Change the spark plugs that you said you have sitting in the garage.
Disconnect the battery for about 30 minutes, while you clean the TB and change the plugs to reset the ECU.
I'd also take the battery into an Autozone and have it checked. Even though it cranks fine, it might be end of life at 3 years old and causing weird things to happen.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 12-11-2023, 09:20 PM #15
Zero0575's Avatar
Real Name: Casey
Zero0575's Avatar
Real Name: Casey
Hewitt.
cel , engine , hesitation , stoplight , tonight
94 3.0 died fastgtfairlane Classic T4Rs 16 08-16-2017 10:56 AM
Need help! 4Runner died HustleHard 4th Gen T4Rs 13 02-03-2017 09:42 PM
3rd gen died today strat10 3rd gen T4Rs 18 07-29-2016 10:55 PM
3rd gen almost died t4r4life 3rd gen T4Rs 45 05-06-2011 07:41 AM
'05 Ltd, GPS just died. briandunning Problems & Warranty Issues 10 10-22-2006 06:40 PM
