Old 11-19-2023, 05:10 PM #1
inscarguy's Avatar
inscarguy inscarguy is offline
Real Name: brian
inscarguy has a spectacular aura about inscarguy has a spectacular aura about
inscarguy's Avatar
Real Name: brian
Fuel trim question
Hi all. I've been chasing down a poor running '08 v8. This thing was a mess when I got it ( dealer screwed me, sight unseen ). Anyway its got 127k on it. This is what has been done by me, basically maintenance stuff:
Full tune up with oem parts
All vacuum lines replaced with OEM lines
Timing belt and pump done
Cleaned MAF and TB
rear cats deleted with URD y pipe
All 4 O2 sensors are original not replaced.
Here's my problem. It uses alot of gas compared to my '06 v8 and has a vibration at idle and higher RPM's. Put my scanner on it, short fuel trims both sides hover between -.07 - 1.5. Long term stays steady b1s1 -1.3, b2s1 +9.3. Those are too far apart. No vacuum leaks(tested with smoke machine). Voltages are within .2 of each other. I'm kinda leaning to a bad bank 2 O2 sensor. If so I would replace both. I just had the left exhaust manifold gasket replaced, and there is a very tiny crack in the manifold. Could the crack be causing the lean cond on bank 2 s1 O2 sensor?
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
inscarguy is offline   Reply With QuoteReply With Quote
Old 11-20-2023, 05:06 PM #2
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
I'd just remove and cap the vacuum lines attached to the intake (PCV, Vacuum Switching Valves...) and re-check LTFTs after some run time.
After this, I'd pull the spark plugs on Bank 2 and look for variation in burn coloration...indicating an injector or two underflowing.
If no leaks, and all plugs on Bank 2 are same burn coloration, then move on to the O2 sensor but use only a Denso or Toyota stock part. No Bosch or other manufacturers.
waypoint is offline   Reply With QuoteReply With Quote
lines , oem , replaced , sensor , vacuum
Normal Fuel trim readings? jross20 3rd gen T4Rs 20 09-19-2019 01:07 AM
Fuel Trim Readings (ScanGauge) psraff 3rd gen T4Rs 10 04-28-2018 09:43 PM
Short term fuel trim specs GangsterOfLove 3rd gen T4Rs 4 08-16-2016 08:43 AM
P0170 Fuel Trim Malfunction (Bank 1) Grapdawg Maintenance/Detailing 3 03-18-2012 11:15 PM
