Old 11-23-2023, 08:40 PM #1
Byways Byways is offline
Byways is on a distinguished road
Replace 1GR-FE valve stem seals
Have you done it? Wisdom and tips to share?
I can't find much at all online for this engine. Just looking for how-to insights, not diagnoses.
A thousand thanks!
Byways
http://www.backcountrybyways.com
Byways is offline   Reply With QuoteReply With Quote
Old 11-23-2023, 10:13 PM #2
zguy1's Avatar
zguy1 zguy1 is offline
zguy1 has a spectacular aura about zguy1 has a spectacular aura about
zguy1's Avatar
I have done them but only with the heads off of the car. They are easy once you have the valves removed.
Not sure how to do them with the heads still in place. Maybe others can chime in.
zguy1 is offline   Reply With QuoteReply With Quote
Old 11-21-2024, 06:33 PM #3
Hig116 Hig116 is offline
Hig116 is on a distinguished road
A thousand thanks!
Did you find the wisdom needed for this, as I'm looking at the same repair and looking for tips as well?
Hig116 is offline   Reply With QuoteReply With Quote
Old 11-25-2024, 02:03 PM #4
alia176 alia176 is offline
alia176 has a spectacular aura about alia176 has a spectacular aura about
See if Tim did a video on this topic. It should be similar to any other V 6 or 8 engine Timmy The Toolman - YouTube
No matter what engine you have, you'll need to remove the valve covers, cam shafts, then use a special tool with an air compressor to pressurize the cylinder. It sounds complicated but once you see a video of this process, it'll make sense.
It doesn't even matter which make/model engine you have, as long as you're looking at an overhead camshaft engine video, the process is quite similar.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 11-26-2024, 11:32 PM #5
Thank you. I’ll check out Tim or look for other overhead cam videos to see what I can learn.
Keith
diagnoses , how-to , insights , replace , thousand
Method 312 Valve Stem Chilow Engines / Suspension / Wheels / Tires / Audio / Accessories 0 05-07-2020 05:41 PM
Identifying valve stem seals eurasiaoverland 3rd gen T4Rs 1 07-17-2016 07:34 PM
Valve Stem Cap Question LexKing 4th Gen T4Rs 6 06-18-2015 04:08 PM
Valve Stem Protection? phillyd2 5th gen T4Rs 9 07-03-2013 12:22 AM
Are there any lockable valve stem cap? pwanghk 4th Gen T4Rs 9 06-05-2005 02:10 PM
