Originally Posted by MikeinNH67
Well that stinks, I was hoping your were getting somewhere. I'm kinda thinking you may have two issues. The original one and one brought on by the supposed "reman" assembly.
Two questions, you mentioned squishy pedal, was that there before the alarms started? Second question, did any ABS codes disappear?
Hi Mike
thanks, yes that squishy brake pedal was there before the failure of the brake system last fall. I am relatively sensitive regarding brakes and I was planning to renovate the brake calipers before the brake failure event.... So this issue was present before.
I am aware the squishy brake pedal is a hardware or hydraulic issue (master brake cylinder leaking or brake calipers stuck or air in the hydraulic system)
The brake alarm with the ABS/TRC acting up (constant brake motor, weird solenoid noise) is the second item and here I can only think it is the electronics (skid control ECU) or something inside the solenoid/valve block.
ABS codes.... good question.
I was trying to understand the codes, but I am not sure.
initially I had 8 stored codes. I believe I have 2 basic events that are here in the code mix
EVENT 1: Super low accumulator pressure triggering the alarm (cancels itself but might trigger a code)
EVENT 2: Solenoid block activated creating this weird hissing sound and constant brake motor
1) C0278 open/short Circuit in Antilock Brake System Solenoid Relay Circuit (EVENT 2)
2) C0279 Battery Short Circuit in Anitlock Brake System Solenoid Relay Circuit (EVENT 2)
3) C1223 Malfunction in Antilock Brake System Control System (EVENT 2)
4) C1246 Malfunction in Master Cylinder Pressure Sensor (EVENT 1)
5) C1252 Hydro-Booster Pump Motor Malfunction (EVENT 1)
6) C1253 Hydro-Booster Pump Motor Relay Malfunction (EVENT 1 or EVENT 2)
7) C1254 Pressure Switch Circuit (EVENT 1)
8) C1256 Accumulator Low Pressure Malfunction (EVENT 1)
Event 1 is the low pressure below the Stage 2 pressure (super low pressure).... causing a low pressure alarm and with this the low pressure codes (codes 4-8...my assumption).
This is an event that happens if I am braking hard hitting the pedal several times in short time... like during race driving. This dash alarm is canceled after the pump motor is picking up the required pressure.
Then there is EVENT 2 , the ABS/TRC/VSC event.... this alarm starts out of the blue (after 10 -20 miles of driving after the alarm is canceled by pulling the green relay), no braking involved in triggering this alarm. This Alarm does not cancel itself. I need to pull the relay in order to cancel.
I believe this failure is triggering the 2 relay codes.
I could spend more time and figure out more. My problem is my cheap code reader (I can easily read the codes but cancelling is difficult, it does not always work...driving me nuts).
Martin
