Originally Posted by werminghausen
Update2
Best Martin
ps I am sorry that this is so lengthy, I wished the problem solving was faster.
Actually this topic has more info on the ABS booster/master cylinder than any other topic I've seen on this forum, it will help many others in the future.
And I maybe the first, it's ironic that I've been following this topic, in the last 2 days my brakes are starting to go bad, after my T4R sitting all night as soon as I turn on the ignition and I get the alarm, brake light as well as the other 3 lights and my brake pedal is hard as a rock, I can barely get it to not roll when I put it in gear if I press hard enough, apparently the pressure has escaped/leaked down, after about 3 to 4 minutes of just having the ignition on the pressure gets build up enough and the alarm and lights go off and the pedal is back to normal.
So far I'm only having this issue after overnight, 6 to 8 hours is sitting no problem.
I pretty sure it's the electric motor, and or the accumulator, but could also be the pump
I think I'm just going to get the entire ABS booster assembly and just get it done.
I may be back asking for advice, or giving it if I can as I go about replacing it, etc.
I will be ordering parts his weekend.
