Old 05-01-2024, 08:00 PM #196
werminghausen werminghausen is offline
werminghausen is on a distinguished road
Originally Posted by SocalSam View Post
Test 1. Motor comes on with key on and runs about 3 to 5 seconds. After that, motor comes on between five and ten stops. I don't notice it and when it does come on, it seems normal.
Test 2. With key on, motor is active so pumping pedal will not tell you anything. With key off, I pumped the pedal 15 times with no degradation in pedal feel or travel. System was holding pressure on both sides of the master cylinder. I turned key on and pump ran 3-5 seconds like it normally does.
Your soon to be replaced valve block has bad master cylinder. On a side note, hydro-boost behavior seems different from vacuum boost system which loses boost after a couple of pedal applications after which pedal becomes hard and brakes like a manual non-boosted system.
Thanks for Testing
Test 1: 5-10 brake hits before the brake motor running? Wow.... my system sucks big time in comparison...My brake motor comes on after every second time on the brake- no question why I am getting the alarm1 after I hit the brake pedal less than 10 times in a row (that alarm 1 goes away after the motor can pick up the super low fluid pressure in the accumulator)
Test 2: if you cannot drain the pressure below stage 2 with the brake motor running... then sure- you are not able to trigger the super low pressure alarm (like I can with simply pushing the pedal 6 times).
Your system seems to work well. That is how it should work. Congrats.
Thanks for testing. This is the first test report and it confirms in what bad conditions my brakes are working (or not working)
I hope Mike can confirm Sam's findings.
Martin
werminghausen is offline   Reply With QuoteReply With Quote
Old 05-02-2024, 04:38 PM #197
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Martin, @werminghausen
I have a question, when I was looking at buying the booster/master cylinder assembly, I saw one on Ebay that was made in China, it was around $850, but it had a warning saying "relieve pressure before installing", would you know what that means and if so how to relieve the pressure?
I now can't find it again.
I didn't buy it, I bought an OEM assembly, which should be here on Friday.
I also received my scanner on Tuesday, turned it on and updated it but haven't had time to check it out yet.
2004 Limited V8
Old 05-02-2024, 08:49 PM #198
MikeinNH67's Avatar
MikeinNH67's Avatar
So mine is pretty similar to Sam's except the motor runs at 2 or 3 pumps of the brakes. Then the 3-5 seconds pump on to keep pressurized. The alarm never goes off no matter how much I pump it but it has in the past. It went off when I blew a brake line and when I had a brake pad seize in the caliper. For the latter, it would only go off if pumped a bunch and I had a super squishy pedal as the pad was pushing the cylinders back in when I let go of the pedal.
One thing about my 220k+ unit is that it is super quiet. I have to listen hard to hear it and local traffic noise would make me miss the sound.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 05-02-2024, 10:10 PM #199
Hi Au
I don't see any reason to buy an unknown Chinese Unit. Good that you bought the Toyota Unit.
In order to relief pressure from the (old) system, before installation of the new unit) just push the brake 20-40 times with the key off . Or you disconnect the red pressure line from the brake pump /accumulator to the master cylinder. the pressurized fluid will push out. That will release all pressure as well.
Martin
Old 05-02-2024, 10:17 PM #200
Real Name: Skip
Real Name: Skip
Originally Posted by werminghausen View Post
Hi Au
Martin
Thanks Martin,
I knew to do the 40 pumps to relieve the pressure from the old unit before removing, I was puzzled by the eBay auction because it was worded as if you had to relieve the pressure from the new unit before installing it.
2004 Limited V8
Old 05-02-2024, 10:37 PM #201
Thanks Mike,
Your motor comes on every 2-3 times you hit the brake. That is quite a difference to Sam's 5-10 times.
You also cannot trigger the alarm but you mentioned that you could trigger the alarm in the past when you had a problem with a seized brake pad that worked like a big spring pushing the brake piston way back... that would be like if you had a lot of air in the system... meaning the master brake cylinder has to pump much more fluid each time you hit the brake.
Interesting and I fear I am having some similar issue with my brake calipers/pads.
I am assuming your brake calipers /brake pads are fine now? and still you have the brake motor much earlier (2-3 times) than Sam (5-10 times).
How squishy is your brake now?
Martin
Old 05-03-2024, 03:32 PM #202
SocalSam SocalSam is offline
SocalSam will become famous soon enough
Now that I am hyper-sensitive to my brakes, I counted the number of stops before the pump came on. It was a lot closer to 5 than 10. Pump came on for a couple of seconds. I'm still satisfied with brake operation. I was just kidding about being hyper-sensitive, lol.
SocalSam is offline   Reply With QuoteReply With Quote
Old 05-03-2024, 04:53 PM #203
MikeinNH67's Avatar
MikeinNH67's Avatar
Martin
Brakes are fine now, yes to both. Only a bit of squish but close to the best they've ever been but certainly not as good as my much newer Sienna. Those brakes are amazing.
Mike
03 4runner Limited
Old 05-09-2024, 12:12 PM #204
update hydro booster:
I installed the new hydro booster, I did no other changes.
The good news:
The brake alarm does not show after I was driving for 2 days. But I am still alert.
The bad news:
The brakes perform just the same as before: Soft and squishy. The brake pedal needs to be pressed too far in order to stop the car.
And the brake motor also comes just the same as before: After every second brake action... that motor runs.
My understanding.... The new hydro booster takes the most annoying brake alarm away (so far!) but it does not improve the braking performance.
Result: The old master cylinder is good. And what triggered the alarm (if the alarm continues to be silent) must then be a problem in the ABS /TRC block next to the master cylinder.
It also means that the squishy brakes are caused by something else in the system (could be calipers or still air in the system)
Where to go from here? What are your thoughts?
Anyone interested in the old hydro booster?
Old 05-09-2024, 05:06 PM #205
The good news:
The bad news:
I wish you could try my brakes and compare to yours.
I'd love to get my hands on a spare mc/abs valve block. I would do a tear down and post photos. Would it fit in a USPS medium flat rate box 11.25 x 8.75 x 6 inches?
Old 05-10-2024, 04:07 PM #206
Real Name: Skip
Real Name: Skip
@werminghausen
Martin,
Did you somehow bleed the ABS system?
If not that could be some of the issue with pedal feel.
Well I'm going to attempt to change out my assembly tomorrow, the electric motor no longer does anything now, constance alarm now, do have any advice or have any difficulties when R&R yours?
2004 Limited V8
Old 05-10-2024, 04:19 PM #207
Removal and install are straight forward.
Old 05-11-2024, 03:07 PM #208
Real Name: Skip
Real Name: Skip
I just finished installing the ABS/master cylinder assembly, so far so good, I only bled the master cylinder at this point and the brakes are pretty good.
It took several minutes to get the alarm to stop, the electric motor on my assembly seems to only run for about 5 seconds then stops for about 5 seconds and then runs again for 5 seconds, this continued for at least 10 cycles before the alarm stopped, I then depressed the pedal about 7 to 8 times and the alarm returned...but only for about 5 to 10 seconds, after that I couldn't get the alarm to trigger even after over 20 depressions of the pedal, I'll report back later as to how many depressions it takes to get the motor to trigger again.
I will at a later date do a full 4 wheel bled and also use my new scanner to bleed the ABS system and post if any improvement over how the brakes work now.
As mentioned it was straightforward to do the R&R....but I would say it was far from easy getting to the 4 nuts under the dash and I have cuts and scrapes to prove it!!
I did have to remove the screws/bolts/nuts for the fuse block and a couple of brackets to gain better access to the master cylinder nuts, I only lost one nut that fell down between the seat and console apparently never to be seen again, I spend close to an hour trying to find it using a magnet and my arms, but no luck, I did however find all the other numerous items I have dropped down there over the last few years!!
2004 Limited V8
Old 05-12-2024, 01:58 PM #209
My re-install was good from the start. No excessive pump run, no alarms, normal braking. I only replaced pump and accumulator so my valve block was wet. I think a new unit is bone dry so it takes some pumping and solenoid action to circulate fluid throughout.
I dropped a nut in some inaccessible spot but got lucky and was able to fish it out with a magnet. Finding right combination of wobblies and extensions for the nuts was easily the hardest part.
Old 05-12-2024, 02:00 PM #210
On a side note, I now have a full set of brake relays. I also snagged the purple A/C relay. Colorful buggers. The donor 2003 was missing ABS/MC assembly. That unit is usually the first to be picked. I wanted to pump the brakes to compare to mine.
brake , brakes , dash , fluid , normal
electrical gremlin 3bears 3rd gen T4Rs 5 04-25-2018 11:59 AM
Electric Gremlin tatooweeny Classic T4Rs 11 09-04-2017 11:45 PM
transmission gremlin nashville67 Classic T4Rs 18 01-30-2011 02:07 AM
Electrical Gremlin Kport 5th gen T4Rs 2 11-11-2010 10:39 PM
4x4 gremlin 4runner1891 Classic T4Rs 3 08-25-2008 07:05 PM
