Old 11-28-2023, 01:52 AM #1
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Parking Brake Shoe Replacement
Hey Dudes,
If you have the need to disassemble and reassemble your parking brake because maybe you left your parking brake on, went driving, and wore down the shoes majorly, or maybe you need to pull your rear axles to perform an axle seal/bearing job, this video will show you how to deal with this very annoying parking brake design.
The parking brake isn't overly complicated. What makes it hard to deal with is the amount of space available between the axle flange and brake backing plate to get in with tools or your hands to disassemble and reassemble the parts. It can be a very frustrating experience and this video will help lessen the amount of frustration you experience.
Hope you guys like the video. Happy Wrenching and Sic Mods for All!
Old 11-28-2023, 06:23 PM #2
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
Some good tips in there, I like that forked tool and using the hub hole. I had to remove one side to replace an axle seal recently. I always have a hard time getting the e-brake cable spring pushed back as it's tough to get a grip on. Didn't help that it was slimy with gear oil. I've had success with the zip tie trick on those shoe spring locks but your way looks good. This job is not for folks lacking finger dexterity.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 11-29-2023, 12:43 AM #3
Poe Mans Dream Poe Mans Dream is offline
Poe Mans Dream is on a distinguished road
I was about to pay a shop $400 to do this for me after two failed personal attempts. Timmay, you are a legend.
'05 Sport V8 - 5100s, DB677V rear coils, Fawkin WP285/70/17, DT Shawty headers, MF catback, MA (mid atlantic) rust & corrosion
Poe Mans Dream is offline   Reply With QuoteReply With Quote
Old 11-29-2023, 11:27 AM #4
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
Looks like a handy tool and a really good video. He gives some great advice on taking a picture before you start; a video would be better. Using the other side as a reference is also a good tip. BTDT Drum brakes are all pretty much like this video shows. You'll encounter some differences but 98% will be the same.
I've been working with drum brakes since my '58 Chevy's 4 drum brakes (and other cars until disc came along) many, many years ago. I used a strong pliers for the top return spring removal and flat tip screw driver to put them back on (hook the spring to the screw driver shaft, flat tip on the post, then pry the driver handle towards the brake). It's tricky but after you've done it a lot you develop a feel for it. You can also grab the spring on the shaft by the hook with Channel Locks and pull the hook to the post. He does this in the video to remove them. At one point he uses grease. I have never done that. I feel that using grease near the brake shoes is looking for trouble. That mechanism is designed to run dry. Never used grease, never had a problem.
For the brake clips I used a pliers to hold and rotate the disc while I held the pin on the back with my fingers. (Or hold the pin with a needle nose pliers and rotate the disc with your fingers) To back off the brakes from the drum there was a slot in the bottom of the backing plate and you needed a special angled tool to reach in and turn the star wheel. It was possible to use a flat tip screw driver too. On these brakes you remove the rotor and the star is visible. After assembly he shows you can adjust through the access hole. That is a good tip for me. I wasn't aware of it.
Our '99 Sienna and '12 Corolla have rear drum brakes, so I get to stay in practice. For someone encountering drums for the first time it can be a daunting task.
There is a brake cable adjuster nut under the console to the rear of the shift mechanism. That's for the Gen4 T4R, I don't know about later models.
It's a great video, especially if you've never done drum brakes. I'm going to "like" it so it will be saved in my YouTube favorites.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 12-01-2023, 09:44 AM #5
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
great video, it's a patience-testing job for sure. It's the only thing I've done that made throw tools and walk away for a day before re-trying again.
I'm terrible about not having proper tools and that fork tool would probably have saved some gray hair. Magnet on the backside pretty damn genius too, might have to give it a try next time
I will say though, I don't think i'll ever do this job again without doing the small zip-tie method to hold the spring/retainers together to get them back on. After practicing on the first side I was able to get the complete passenger side together using that method in literally 15 minutes
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
aemravan is offline   Reply With QuoteReply With Quote
Old 12-01-2023, 07:23 PM #6
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
The grease applied to the rear spring plate to give it some holding power to the shoe isn't going to be an issue. The Toyota FSM instructs to put grease on the backing plate raised spots so the shoes move smoothly when they contract and extend. You also apply grease to the shoe lever pin and adjuster. There's grease all around the brake shoes and it's not an issue. I have a fair amount of experience working with drum brakes and I've always used grease where the Toyota FSM recommends you put it.
We were originally going to use a panel clip remover tool to compress the hold-down spring assembly while rotating the shoe into position. We tried it with an altered pry bar, and it works, but it's still was a bit of a fight. A person commenting on the video gave us a link to a panel ciip remover tool he said works well for this application. We're going to give it a try this coming Wednesday and film the result.
Old 12-02-2023, 10:47 AM #7
Montego Murph's Avatar
Montego Murph Montego Murph is offline
Montego Murph will become famous soon enough Montego Murph will become famous soon enough
The zip tie trick is a total gamechanger. When I first did mine a few years ago, those little clips took me what seemed like hours to take care of. Earlier in the summer I did a friend's parking brake with the zip ties in less time than it took him to do his front calipers on and off.
I just wish Toyota would have put some sort of cutout in the hub to work around!
Montego Murph is offline   Reply With QuoteReply With Quote
Old 12-03-2023, 03:53 AM #8
toyo's Avatar
toyo toyo is offline
Real Name: Steven
toyo will become famous soon enough
toyo's Avatar
Real Name: Steven
Another trick I have learned and use is I will take some super glue and apply it to the inside of the head to the shoe hold down pin. Put the pin in and it will stay attached to the backing plate. This will free up a hand/finger that you would use to hold the pin in place while putting the spring and cup on. When you have them installed take a small screwdriver and from the backside of the backing plate just tap on the pin and it will break free and not be glued anymore.
2008 4R LTD V8 4WD, ICON Stage 3, TRD Pro Wheels, GOBI Rack, TRS HID Swap along with too many other mods to list here!
toyo is offline   Reply With QuoteReply With Quote
Old 12-30-2023, 12:02 AM #9
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Here's another trick on how to deal with getting the shoes back into position and locked down by the hold-down spring assembly.
I think you guys will appreciate it. If features a tool that only costs $5. Maybe not as affordable as the zip tie trick, but it's a fast way to get the job done.
brake , deal , experience , parking , video
4th Gen V6 Parking Brake Replacement Advice ryanarcane 4th Gen T4Rs 2 02-28-2021 10:18 AM
Parking brake cable replacement drivermod 4th Gen T4Rs 1 05-27-2020 05:14 PM
Parking brake/shoe hold down pin bumada 4th Gen T4Rs 5 07-16-2018 07:05 PM
Drum Brake Shoe Replacement mtbtim 3rd gen T4Rs 59 01-19-2018 04:04 PM
96 T4R Rear Brake Shoe Replacement trtalley 3rd gen T4Rs 2 06-30-2012 11:27 AM
