Old 12-17-2023, 02:23 PM #16
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
At that mileage, I would also recommend changing the LBJs. They are most likely worn out too. I bought Pro forged from rockauto but Im not sure they still sell them. Made in USA and million mile warranty. This thread was helpful.
proforged LBJ
How I replaced lower ball joints on FJ | Toyota FJ Cruiser Forum
Here is a good thread on replacing the front wheel bearings.
front hub bearing R&R
Orig thread minus pictures. *How to* - front wheel bearing replacement | TTORA Forum
Look for made in Japan like NSK bearings rockauto $56 each
2007 TOYOTA 4RUNNER 4.0L V6 Wheel Bearing | RockAuto
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 12-18-2023, 12:15 AM #17
4R005 4R005 is offline
4R005 is on a distinguished road
@R4Adventure Its 150 and not 250 ft. lbs. My bad, a senior moment. Apologies.
@d33pt No specs for the 4 bolts. Space is limited to only a 17mm box wrench to undo/install.
4R005 is offline   Reply With QuoteReply With Quote
Old 12-18-2023, 01:15 AM #18
d33pt d33pt is offline
d33pt is on a distinguished road
I guess those bolts are not that important? Since the whole thing is held in by the big center nut.
d33pt is offline   Reply With QuoteReply With Quote
Old 12-18-2023, 12:42 PM #19
No! the 4 bolts hold the bearing & wheel hub assembly to the knuckle assembly and must be tightened.
Just that the wheel hub/bearing unit are such closely joined together that these bolt heads accessibility are very restricted and only a box wrench can fit over them. Even then as you undo the bolts, it can only move out a little and the whole hub/bearing unit has to move out with it i.e. away from the knuckle assembly.
These 4 bolts cannot be removed/separated completely from the hub/bearing unit ( unless the hub and bearing are separated with a press).
If you check RockAuto catalogue for this hub/bearing unit it'll be easier to visualize. Note: two types of front wheel bearing/hub units. The 4x4 and the RW drive only are not the same and not interchangeable.
The bearing and the wheel hub if bought separately will require a shop press to join them together with the 4 bolts already in place in the bearing flange.
Old 12-18-2023, 05:47 PM #20
MikeinNH67's Avatar
MikeinNH67's Avatar
Those bolts are super important, the big center nut only holds the CV in place unlike cars of old and trailers.
This is where a geared box end wrench shines.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 12-18-2023, 06:10 PM #21
Got it done! With it being a rust free truck, everything just fell off when I loosened the bolts. Didn't have to fight the rotor, or hub, or CV.
I got those 4 bolts as tight as I could with an extra long box wrench.
The worst part of the job was getting the new knuckle seal in. Toyota wanted $60 for one! So I got the Napa seal. It was a pain in the ass to get in and hopefully I didn't damage the sealing surface. It has a spring in it, so hopefully that will keep it tight.
Thank you all for the tips. It was actually pretty straight forward, but seemed a lot harder on paper.
I got a pair of pressed hubs, so I'll do the other side at some point. Just not an emergency since it's still tight.
Old 12-18-2023, 08:24 PM #22
@d33pt Good job, bud !! Now treat yourself to several beers. Cheers.
Old 12-18-2023, 09:49 PM #23
I shouldn't need an alignment right? I might get one anyway since it was so loose before. Any previous alignment wouldn't have been accurate anyway. But I shouldn't need one after doing the other side in the future?
Old 12-18-2023, 10:32 PM #24
Drcoffee's Avatar
Drcoffee's Avatar
The 4 bolts that hold the bearing to knuckle are torqued to 59Ft# but its impossible to use a torque wrench even with a crows foot. Use red loctite and tighten it as much as you can.
Bad front wheel bearing?-img_4609-jpg
Old 12-19-2023, 05:09 PM #25
MikeinNH67's Avatar
MikeinNH67's Avatar
I wouldn't bother unless you see abnormal wear or steering off. Any good alignment shop should notice a bearing that is that loose but that doesn't say much.
Mike
03 4runner Limited
Old 12-21-2023, 10:49 AM #26
R4Adventure's Avatar
R4Adventure R4Adventure is offline
R4Adventure is on a distinguished road
Job well done. You saved a lot of money and have more experience now. That's a win win in my book.
My 4Runner is also rust free. That made a tremendous difference. My buddy's Tacoma was not, and it was a bit more challenging.
For future reference, the Napa seal is ok but there are plenty of online Toyota dealers that sell OEM parts at a reduced cost. I buy a lot of my parts from Olathe Toyota Parts Center
Also, you can usually find Timken seals on Amazon or at other locations. Timken is an OEM supplier and usually is less expensive than the factory seals.
You also reminded me that I need to buy a seal installer kit. That makes installing these parts way easier.
R4Adventure is offline   Reply With QuoteReply With Quote
Old 12-21-2023, 02:25 PM #27
Unfortunately, I didn't plan it well and the only dealership in town that had the part wanted $60 for it. That's $15 more than MSRP! I don't ever plan on doing any business with them in the future. The dealership I normally buy stuff from has it for $30, but they were out of stock for the foreseeable future. I would've ordered it online if I had more time.
front , oclock , play , smooth , tire
Front wheel bearing? chimpy 3rd gen T4Rs 19 11-05-2020 11:44 AM
Front wheel bearing kolelt 3rd gen T4Rs 18 10-30-2017 03:28 PM
Front Wheel Bearing?? Louisville4Runner 4th Gen T4Rs 12 04-11-2014 12:51 AM
Unknown Creak from front right wheel, not ball joints, wheel bearing?? ryanbigcheese Classic T4Rs 2 02-23-2014 12:47 PM
Front Wheel Bearing for 03+ 4WD Cubslover For Sale: T4R Items 1 08-02-2011 10:18 PM
