Old 12-05-2023, 07:26 PM #1
d33pt d33pt is offline
d33pt is on a distinguished road
Bad front wheel bearing?
When I rock the tire holding at 12 and 6 o'clock, I get quite a bit of play. About 1/8" with a clunk. Same at 3 and 9 o'clock. When I spin the tire, it feels "coarse" or rough, best I can describe it. There is the usual disc brake drag, but it doesn't feel as smooth as the other side.
Truck has 214k miles. Other side is perfectly smooth when spun and no play with rocking. Rears are also tight.
I've never replaced front bearings before. What's the consensus? Only OEM parts? Any good guides on doing this?
d33pt is offline   Reply With QuoteReply With Quote
Old 12-05-2023, 10:41 PM #2
zguy1's Avatar
zguy1 zguy1 is offline
zguy1 has a spectacular aura about zguy1 has a spectacular aura about
zguy1's Avatar
I replaced mine myself. Wasn’t too bad. I’m not a fan of the typical aftermarket brands like Dorman, Moog or Timkem. Those brands never lasted for me on other vehicles I have owned. You will get varying opinions on that though.
I got my bearing assembly from Bluepit. You can buy a new bearing itself but you will need to press it out of your existing hub and then reinstall. That will require a press though.
See my old thread for additional info when I did mine.
Another wheel bearing question???
zguy1 is offline   Reply With QuoteReply With Quote
Old 12-06-2023, 12:21 AM #3
MrSeth's Avatar
MrSeth MrSeth is offline
Real Name: Seth
MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough
MrSeth's Avatar
Real Name: Seth
I would say YES, that side is cooked. I would replace both front wheel bearings at once. I have been running TRQ front wheel bearings for several years now with zero issue!!
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
MrSeth is offline   Reply With QuoteReply With Quote
Old 12-06-2023, 05:41 PM #4
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
Sounds like a bearing to me. Assuming you are wanting the hub/bearing assembly, the options for non-china bearings are limited. If you can find one with a Japan made bearing, that is your best bet. Here's a quick video for a tip on pulling the assembly.
GEN 4 Toyota 4Runner Front Bearing Replacement Tips! - YouTube
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 12-06-2023, 07:17 PM #5
Kandor's Avatar
Kandor Kandor is offline
Kandor will become famous soon enough
Kandor's Avatar
I had to replace both of my frt wheel bearings not long after 200k miles. Replaced one side and a few month later the other started acting up. Went with OEM.
2007 Limited V8 - Sold
2023 TRD ORP
Kandor is offline   Reply With QuoteReply With Quote
Old 12-06-2023, 08:07 PM #6
I'll probably get a Napa lifetime warranty hub assembly for about $200. Just the bearing from toyota is already around that much, and I'd have to press it out. Doesn't look too hard to swap out if you get the whole assembly. The truck in that video is sooo crusty. Mine should be a breeze.
Old 12-06-2023, 11:37 PM #7
MikeinNH67's Avatar
MikeinNH67's Avatar
That would be my truck and that is what we deal with up here.
Mike
03 4runner Limited
Old 12-08-2023, 02:28 PM #8
I ordered a set of built hubs to swap in. I've been told that I need these seals.
Knuckle....90316-A0001
CV............90304-A0001
Where do they go during the install? I did see a pic of a seal behind the backing plate I think it was. Would that be the knuckle seal? How about the CV seal?
Old 12-08-2023, 04:24 PM #9
MikeinNH67's Avatar
MikeinNH67's Avatar
One seal is on the back side of the knuckle and seals against the CV. The other one looks like it's part of the hub assembly and is only needed if you replace just the bearing and not the whole unit. BTW, the last assembly I bought came with the knuckle seal.
Mike
03 4runner Limited
Old 12-14-2023, 04:02 PM #10
4R005 4R005 is offline
4R005 is on a distinguished road
Did the passenger side of my '05 4R w/V8 2 months ago when I noticed movement while changing out a bad ABS sensor. Did driver side 5 years ago when wheel contacted curb and bent hub. Its the wheel bearing for sure when you've got movement at all 4 clock positions. R&R is pretty straight forward/easy if the hub is not rusted bad to the knuckle ( watch video from Eric the CarGuy on YT. He had a hell of a time for the hub removal part ). Tip: if your dust shields are not in the best of shape, I'll recommend to change them when you're doing the hub switch. They fit between hub flange and knuckle. I got them from Toyota dealership cos they were nowhere to be found otherwise. Bearing w/hub assembly from RockAuto. Many choices from cheap to pricey if you decide to stay away from dealership.
You'll need a long cheater bar to undo the hub nut. Socket size I believe is 35 mm if memory serves me correctly. !/2 " drives are adequate. Install torque for this nut is like 260 ft.lbs. I maxed out my torque wrench @ 250 and gave it a bit extra.
Happy wrenching to you & season's greetings to all.
4R005 is offline   Reply With QuoteReply With Quote
Old 12-14-2023, 05:30 PM #11
Toystory2's Avatar
Toystory2 Toystory2 is offline
Toystory2 will become famous soon enough
Toystory2's Avatar
Appreciate the good tips here! Got to replace my left front bearing real soon.
Toystory2 is offline   Reply With QuoteReply With Quote
Old 12-15-2023, 10:22 AM #12
R4Adventure's Avatar
R4Adventure R4Adventure is offline
R4Adventure is on a distinguished road
I did this job on my 04 a few months back. 4R005 is correct, it's a 35mm socket. The FSM states the torque on the axle nut is 173ft lbs.
If you have an impact gun, it will make your life easier getting that bolt off. Otherwise, a longer breaker bar is required. To get to that 173 ft lbs torque, you will need a bigger torque wrench. Most common torque wrench used typically goes up to 150 ft lbs, and even still that's a challenge.
I bought a Tekton torque wrench off amazon that did the job very well:
Amazon.com
I think the 35mm socket I bought is also from TekTon.
I also attached a section from the FSM that covers all the torque values:
Screenshot 2023-12-15 at 8.30.13 AM
It's not a difficult job. There's several YouTube videos out there on how to do this.
R4Adventure is offline   Reply With QuoteReply With Quote
Old 12-15-2023, 10:31 AM #13
Boise Tim Boise Tim is offline
Real Name: Tim Abernathy
Boise Tim is on a distinguished road
It's an easy repair
Hello everyone. I am new to the forum. I replaced both front bearing assemblies last week. It took me 45 minutes per side with basic tools. Although you will need a 36mm socket for the axle nut.
Also, after I did the repair for the bearings, both sides still had movement. it turns out that my bushings for my lower control arms were done. Had to replace the lower control arms each side. Another easy repair. Now the front end is great!
Just have to replace my blown transfer case now.
Boise Tim is offline   Reply With QuoteReply With Quote
Old 12-16-2023, 05:15 PM #14
What's the torque spec on the 4 hub bolts?
Old 12-17-2023, 02:22 PM #15
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
At that mileage, I would also recommend changing the LBJs. They are most likely worn out too. I bought Pro forged from rockauto but Im not sure they still sell them. Made in USA and million mile warranty. This thread was helpful.
How I replaced lower ball joints on FJ | Toyota FJ Cruiser Forum
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
front , oclock , play , smooth , tire
Front wheel bearing? chimpy 3rd gen T4Rs 19 11-05-2020 11:44 AM
Front wheel bearing kolelt 3rd gen T4Rs 18 10-30-2017 03:28 PM
Front Wheel Bearing?? Louisville4Runner 4th Gen T4Rs 12 04-11-2014 12:51 AM
Unknown Creak from front right wheel, not ball joints, wheel bearing?? ryanbigcheese Classic T4Rs 2 02-23-2014 12:47 PM
Front Wheel Bearing for 03+ 4WD Cubslover For Sale: T4R Items 1 08-02-2011 10:18 PM
