Old 12-06-2023, 06:05 PM #1
SilverCoMnt07's Avatar
SilverCoMnt07 SilverCoMnt07 is offline
SilverCoMnt07 is on a distinguished road
I know, another VSC light thread
Picked up a 2004 V8 limited on Monday super cheap. It needed an alignment and thereís some lights on the dash. It wanders bad, itís like Iím driving in 100mph winds, constant correction when going over 50mph.
Had a tune up and alignment done, checked for codes none came back. Mechanically sheís great for her age. VSC, ABS and Trac off lights are still on. Still wanders like crazy. Not pulling, no braking issues. Itís like itís floating back and forth. Took back to the shop, they adjusted the toe but otherwise said everything was in spec. Guy blamed the lights being for the problem. Offered no other solutions.
Is that possible? The lights being on are causing instability in suspension? Iím going to obviously check the ABS sensor and maybe do a zero point calibration but I wouldnít think the lights are causing the wandering.
SilverCoMnt07 is offline   Reply With QuoteReply With Quote
Old 12-06-2023, 08:38 PM #2
Syr4RinNC's Avatar
Syr4RinNC Syr4RinNC is online now
Syr4RinNC's Avatar
I would an OBDii read out. If you dont have one - go to Autozone/ Advance auto and see what it says and whats causing the lights
Syr4RinNC is online now   Reply With QuoteReply With Quote
Old 12-06-2023, 11:47 PM #3
MikeinNH67's Avatar
MikeinNH67's Avatar
You're gonna have to pull the ABS codes, that may just be a wheel speed sensor setting those lights. The wandering has gotta be something else. Seeing they checked the front end, I would check the intermediate steering shaft u-joint for slop. Turn the key to unlock the steering wheel but not start the car, then see how much steering slop there is and if there's any noise.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 12-07-2023, 07:12 AM #4
earthrealm earthrealm is online now
earthrealm will become famous soon enough earthrealm will become famous soon enough
obd scanners are cheap now, especially the bluetooth type. pick up this unit from amazon, download the motordata app on playstore...and read codes at home. the app can also read abs codes. also do a zpc/abs reset
Amazon.com
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is online now   Reply With QuoteReply With Quote
Old 12-07-2023, 10:18 AM #5
Thank you for the responses.
I had the codes read and nothing is coming up related to the VSC/Trac off lights. The CEL came on and itís the thermostat but that was after the other lights had already been on. Replacing the thermostat Saturday.
Iíll check for steering slop today and go from there. I also feel like the shock on the passenger side is sagging. Iím doing a lift kit this weekend, replacing shocks and struts so that should be corrected.
2007 SR5 4wd. Titanium Metallic (AKA Silver). Daystar 2.5/1.5 spacer lift. Stock wheels and tires. Plasti-dipped emblems and wheels. More to come SOLD
Old 12-07-2023, 10:28 AM #6
zguy1's Avatar
zguy1 zguy1 is offline
zguy1 has a spectacular aura about zguy1 has a spectacular aura about
zguy1's Avatar
If the VSC or ABS light is on then there will be a code or codes set. A cheap or typical code reader does not read from VSC / ABS module.
zguy1 is offline   Reply With QuoteReply With Quote
Old 12-07-2023, 12:30 PM #7
it does, the cheap 30 dollar bt unit i posted the amazon link above does. you need to mate it with a decent app...and i also named the app i use above.
@SilverCoMnt07 try doing a zero point calibration to remove the vsc & trac light
Old 12-07-2023, 12:43 PM #8
billbuckets billbuckets is offline
billbuckets is on a distinguished road
VSC, ABS, TRAC OFF lights etc came on for me intermittently with no CEL. Ended up replacing the brake light switch behind the brake pedal, and no lights for over a year! Found out about it from watching Canadian Gearhead on youtube lol. Super cheap and easy too. Something to consider!
I have also heard cheap aftermarket LED headlight bulbs can cause electrical interference FWIW.
Hope you figure it out!
2007 Sport Edition 4.0 V6 4WD - Dobinsons IMS, JBA HD UCA, SuperPro Double Offset LCA, Sony DSX-GS900 Head Unit, Alpine Type-S 12" Subwoofer, JBL GTR-601 Amplifier
billbuckets is offline   Reply With QuoteReply With Quote
Old 12-07-2023, 03:49 PM #9
MikeinNH67's Avatar
MikeinNH67's Avatar
SilverCoMnt07, how did you have the codes read? An issue in the ABS system will set off the VSC/Trac & ABS light but basic code readers often won't pull ABS codes. If you do not have an ABS light on then the issue is elsewhere and something like zero point calibration may fix it. BTW, some code readers will set off the VSC/Trac lights with no ABS light, the calibration method usually clears those.
Earthrealm, you mention the Veepeak one which I have an older model of. Mine will not pull ABS codes and their website does not mention it. Usually it's the ones closer to $100 that will pull them. I don't understand why yours works unless the app is pulling PIDs that mine doesn't pull.
OBDCheck BLE+ – Veepeak
Mike
03 4runner Limited
Old 12-07-2023, 03:51 PM #10
zguy1's Avatar
zguy1's Avatar
I suppose I may have generalized, point being a code can be set in the VSC / ABS module but not set a CEL light. We don't know how the OP "pulled the codes".
Old 12-07-2023, 04:27 PM #11
MikeinNH67's Avatar
MikeinNH67's Avatar
BTW, if the ABS light is on then the zero point calibration process will not help. Whatever is tripping that light would need to be fixed.
Mike
03 4runner Limited
Old 12-07-2023, 09:33 PM #12
timbird1219's Avatar
timbird1219 timbird1219 is offline
Real Name: Tim
timbird1219 is on a distinguished road
Real Name: Tim
I had the VSC OFF and VSC TRAC lights on for awhile now I just did a zero point calibration yesterday and it worked fine and they are staying off. Fairly easy to do yourself just google how to do it on your t4r because I donít remember the exact steps.
timbird1219 is offline   Reply With QuoteReply With Quote
Old 12-07-2023, 11:36 PM #13
warrig warrig is offline
warrig is on a distinguished road
will add, one can disable the trac control and nanny switches by unplugging the steering angle sensor in the steering column.
did this on a tundra as i could not stand 3 button presses to get the thing to drive like a normal truck on dirt roads. all of three traction lights came on for something like 10-20k miles. but now only one remains, i.e. the slippery when wet one. been 8+ years ago and ~100k miles, with many not on paved roads.
just did this to the 4runner. the 3 trac lights are on like it is xmas. TBD if they turn off like the tundra.
disclaimer, one does lose the trac control, VSC is permanently off so no more dead pedal. this only impacts me when the caddy corner front and rear tires are not touching ground which is a rare occurrence that i can often avoid. all other stuff works normal, i.e. 4wd hi/lo, differential lock.
warrig is offline   Reply With QuoteReply With Quote
abs , back , itís , lights , wanders
Another Reverse Light Thread Ausumm General Discussions 12 12-01-2017 01:32 PM
Another LED light bar thread Elomar88 3rd gen T4Rs 18 11-20-2017 03:06 PM
looking for thread, 2014 fog light mod FiReBReTHa 5th gen T4Rs 2 06-05-2016 12:36 PM
Another light conversion thread. Jbot 3rd gen T4Rs 2 08-16-2013 01:34 PM
Another 4WD light blinking thread? jreask 3rd gen T4Rs 5 08-12-2010 09:03 PM
