Old 12-14-2023, 09:00 PM #1
bninja bninja is offline
bninja is on a distinguished road
Got my first 4th Gen today! Couple questions
Snagged a '07 V8 Sport today, 218k on the clock. I live in the rust belt and this truck has lived its entire life in Texas except for a year in Oklahoma so blessedly no rust!! Truck had some nice maintenance covered about 20k ago..
Bilstein 4600 stut and springs,
New Trd Pro 17" rims wrapped in Geolander AT's
Timing belt and water pump
Front axles & wheel bearings
Rear U Joints
Tie rod ends
Diff, Transfer Case, Transmission fluids done
New battery
Brakes and rotors
New headlight housing with upgraded LEDs
She's super solid but not without a few issues..
Driver side leaky steering rack, doesn't seem terrible but the boot has broken down a bit. Can these be rebuilt or am I looking at putting a new rack in?
Lower oil pan is seemingly leaky but haven't fully diagnosed it. Wiped clean today but need to get back under there. Is this a common problem on a higher mileage V8 or should I be looking elsewhere for the culprit?
Sunroof seal isnt great, will probably just seal it shut since it looks like the only way to get the seal is with new glass. Any other options I'm overlooking?
Lastly I'm like 99% sure the seats are aftermarket covers. I have a small wear spot in the driver's bolster. Can anyone help me ID these?
Plan is to daily her and building out my 3rd gen as a trail/camp rig
bninja is offline   Reply With QuoteReply With Quote
Old 12-14-2023, 10:02 PM #2
Curious why my photos aren't imbedded? Been a while since I've been on here but don't i just use [IMG ] [/IMG]
without the additional space?
Old 12-14-2023, 11:45 PM #3
SocalSam SocalSam is offline
SocalSam will become famous soon enough SocalSam will become famous soon enough
Congrats. Black leather looks great.
Code is correct to display. Use each photo's link to embed.
SocalSam is offline   Reply With QuoteReply With Quote
Old 12-15-2023, 03:51 AM #4
dfontes's Avatar
dfontes dfontes is offline
dfontes is on a distinguished road
dfontes's Avatar
Rear U Joints
Tie rod ends
New battery
Brakes and rotors
Plan is to daily her and building out my 3rd gen as a trail/camp rig.
Congrats on the V8 4Runner! Recently bought one my self that needed similar work.
I also had a leaking steering rack that needed to be replaced. I bought a remanufactured one from the Toyota dealership because it's about half the price of a new one. You want to go OEM with expensive parts like this for longevity. Cry once, buy once.
Was it just the oil pan that was covered in oil? I had to replace my valve cover seals because there was oil that seeped all the way down to the oil pan area. You may want to check around your valve covers because it is a common thing that needs to be replaced about every 150k.
What does the tag say on your passenger side seat next to the seat belt? Clazzio, katzkin, and leatherseats.com are some of the more popular leather seat covers you'll see around here.
Fortunately, a lot of the work is simple enough to do yourself, especially with no rust. These trucks will run for a very long time if you maintain them.
Get an undercoating before it snows!
dfontes is offline   Reply With QuoteReply With Quote
Old 12-15-2023, 09:11 AM #5
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Re-route your AC condenser drain line away from dripping on top of frame on passenger side inside engine compartment. It drips right on top of the frame, runs down to a point under passenger side front door, accumulates and drips on ground, While doing so it causes a major rust area on frame at that point.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 12-15-2023, 11:32 AM #6
This is the first I've heard of this one, will definitely be looking into it thanks!
Old 12-15-2023, 11:45 AM #7
I was also looking at the remanned racks. How's yours holding up? Was curious how they were compared to new.
I don't think they are the Clazzios unless they are an older model, the stitching pattern doesn't match up. I'm going to hunt for a tag later.
Just got her yesterday so need to get back underneath and really track down the leak, doesn't seem bad just a little wet. I'll update with some pics later. (Anything but the rear main plz 🤞)
100% all ready ordered some Por15 and fluid film. Plan is to hit the outside with the Por15 then give everything a nice coat inside and out of Fluid Film.
Old 12-15-2023, 11:53 AM #8
Thanks! Got it updated
Old 12-15-2023, 11:54 AM #9
swampdodo swampdodo is offline
swampdodo has a spectacular aura about swampdodo has a spectacular aura about
Looks good, congrats!
swampdodo is offline   Reply With QuoteReply With Quote
Old 12-15-2023, 06:02 PM #10
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
Nice looking rig, those seats look nice in black. Normally I would think the tag was one that says airbag. With the rack, verify it's not a leaky line first as that is a common issue but maybe not so much with a Southern car.
As for the frame, after every winter wash out the inside keeping close attention to the lowest parts near the wheel arches. This area collects sand, add some salt to that and you get holes like mine has. I dug out sand that was over an inch thick. If I had a Southern frame, yearly I would run a borescope down all the areas prone to rust and make sure there's no muck in there then oil the inside. I'd probably drill a 1" hole at the bottom of the wheel arches for a cleanout.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 12-18-2023, 12:47 PM #11
mitch86 mitch86 is offline
mitch86 is on a distinguished road
Looks good! Congrats!
You'll probably need a new steering rack unfortunately. I had the same issue.
mitch86 is offline   Reply With QuoteReply With Quote
Old 12-21-2023, 11:48 AM #12
R4Adventure's Avatar
R4Adventure R4Adventure is offline
R4Adventure is on a distinguished road
Welcome to the 4th gen club. I just bought an 04 v8 with a super clean frame, earlier this year. Just an SR5, but that's fine.
Looks like you have new TRD style rims too.
R4Adventure is offline   Reply With QuoteReply With Quote
Old 12-26-2023, 01:16 AM #13
Figured I'd throw an update in this thread just because I'm excited to have the undercoating done and ordered myself the Magnaflow Overland Catback as a nice little Christmas present to me. Will be here Friday and hoping to get it in this weekend. Just wish I had got it installed before spraying everything with Fluid Film..
If anyone in the Cincinnati area is looking for a very clean OEM catback hmu, going to try to not cut it out. Only reason I'm replacing is I want a bit more V8 sound.
Old 12-26-2023, 12:47 PM #14
Boise Tim Boise Tim is offline
Real Name: Tim Abernathy
Boise Tim is on a distinguished road
new guy here
Hello everyone. I am new to the forum. I found this thread and thought I could ask for some help with my 04 t4r. I bought it 16 years ago and it now has 240k miles on it. I had the dreaded T-case leak for years and it looks like I let it go too long between fluid fill ups. It's done. I bought a replacement from a newer Lexus model and will be swapping it out myself. Does anyone know a repair thread or a really good place to get a factory repair manual. I want to have something I can reference when I start this replacement.
Boise Tim is offline   Reply With QuoteReply With Quote
Old 12-26-2023, 04:53 PM #15
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
You should start your own topic/thread and not be high jacking someone else's topic, you will not only get more "views" but also more replies related to your problem!
2004 Limited V8
leaky , rack , rust , seal , today
Checking out a couple 4Runners today - need some help! Spicy McHaggis 3rd gen T4Rs 15 11-25-2018 11:07 AM
Looking at a 4th Gen, have a couple questions. Awz 4th Gen T4Rs 10 01-15-2016 09:32 PM
A couple questions... WU7X 3rd gen T4Rs 3 05-05-2012 09:29 AM
Couple questions! 2003Can4runner 4th Gen T4Rs 2 05-09-2010 12:11 PM
First oil change today, couple of observations - questions G.I.G. 4th Gen T4Rs 11 09-23-2007 10:18 PM
