Originally Posted by villaphoto
No other holes that I can think of. Might try checking the seal of where your back hatch closes at the rear of the vehicle though. That could potentially let water in.
Thanks.
My leak is resulting in a wet drivers seat belt. Water is getting into the B pillar, somehow. I've seen a few posts about 5th gens having this issue, but little in regards to 4ths.
Mine does have a sunroof and both drains test fine and the glass frame does not have any rust like others have experienced. My drains have clogged in the past, so I'm familiar with that flood pattern and this is different. I'm confident in saying that it's not the sunroof at this point.
The roof rack mount doesn't quite line up with the B pillar, but it may be close enough. I RTVd the bolts and the little plastic insulator holes yesterday, so hopefully that was the issue. The 13 year old cover shattered like it was glass, so I've got to replace that now...
