Old 12-18-2023, 11:56 AM #1
ThatRed4thGen's Avatar
ThatRed4thGen ThatRed4thGen is offline
ThatRed4thGen will become famous soon enough
Anyone running a 1" wheel spacer?
I'm trying to find examples of a 1" wheel spacer on a 4th gen 4runner. I've only been able to find 1.25" which is a little wider than I want. I'm curious if anyone is running one and if they had to cut down the wheel studs or not.
TIA
Sent from my SM-G998U using Tapatalk
ThatRed4thGen is offline   Reply With QuoteReply With Quote
Old 12-18-2023, 01:10 PM #2
MountainBiker MountainBiker is offline
MountainBiker is on a distinguished road
I'd like to know this as well!
FYI, I tried the 3/4" wheel spacers and they don't fit a 4th gen.
WHEEL SPACER KIT HUBCENTRIC 6X5.5
- The rear wheel studs in the hub are too long and poke through the spacer and it the wheel. Could be solved by installing shorter wheel studs
- The front hub cap (the steel one that is hammered into the hub over the axle nut) interferes with installing the 3/4" wheel spacer. This is because the spacer is hub centric, and needs material to from the OD of the hub to the ID of the wheel, and at 3/4" thick, there isn't enough distance to achieve the fit. Possible solution is to turn down the wheel spacer, but it might get too thin.
2000 Limited: Toytec Superflex, 255/85-16, Lil Skips gas tank skid, SaVage rear bumper and skids, BAMF Sliders
2006 SR5: FJC Coilovers +2", Toytec Superflex, 255/85-16
Sold: 2017 TRD OffRoad Prem (this rig was too nice for me!)
MountainBiker is offline   Reply With QuoteReply With Quote
Old 12-18-2023, 03:57 PM #3
inscarguy's Avatar
inscarguy inscarguy is online now
Real Name: brian
inscarguy has a spectacular aura about inscarguy has a spectacular aura about
inscarguy's Avatar
Real Name: brian
I am. I'm running a 1" on the front of both of my 4runners and 1.25" on the rears. My '06 has no rubbing as it sits about 1-1.5 inches higher in the front than my '08 does. There is very slight rubbing on the '08 but I have to do one more small trim to the mud flaps and then it will be ok. Both sets are hub centric and they are KSP brand. They have been on for over a year and no issues. Both are running 275 55 20's with the '06 running michelin ltx at.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
inscarguy is online now   Reply With QuoteReply With Quote
Old 12-21-2023, 03:23 PM #4
ktom3001 ktom3001 is offline
ktom3001 is on a distinguished road
The spacer is attached to the hub with nuts so there's a minimum material thickness behind those nuts. I think that's why they all end up being 1.25".
Not to sound like I'm lecturing but I really think these wheel spacers are a bad idea, if you can find a wheel/tire combo that gets the look you want then go that route for safety sake.
ktom3001 is offline   Reply With QuoteReply With Quote
Old 12-21-2023, 04:58 PM #5
inscarguy's Avatar
Real Name: brian
inscarguy's Avatar
Real Name: brian
You can also get shorter lug nuts which fit the 1" spacers. They fit perfectly.
cut , find , running , spacer , wheel
Anyone running bora 1inch or .75 wheel spacer? titan34 Engines / Suspension / Wheels / Tires / Audio / Accessories 3 11-20-2017 10:32 PM
Anyone running a 1" spacer with the Bilstein 6112 setup ? JOEYD215 5th gen T4Rs 1 05-23-2017 10:14 AM
FS spacer 6 Lug 6x5.5 Aluminum Wheel Spacer 1.25" Thick Hub Centric, $100 Las Vegas Jeremy_A For Sale: Suspension/Wheels/Tires 0 11-20-2016 11:14 PM
WTT: SpiderTrax Wheel Spacer 6x5.5 1.25" for 1.50" T4R120 For Sale: Suspension/Wheels/Tires 9 12-11-2015 02:28 AM
anyone running 1.25 allpro wheel spacer mmjmeade 4th Gen T4Rs 0 03-09-2010 07:50 PM
