Old 12-21-2023, 07:21 AM #1
fredty fredty is offline
fredty is on a distinguished road
Up on jacks and running, cannot rotate Right wheels by hand
hello,
With my 4Runner up on jackstands, no matter what drive mode it is in (2 wheel drive, 4 wheel drive, locked, unlocked, reverse, etc.), only the Lefts wheels rotate.
The Right wheels remain NOT rotating AND I cannot rotate either Right wheel by hand.
Although it is common to see only 2 wheels on one side rotate while in 4-wheel drive mode, I am surprised the Right side wheels cannot be rotated by hand.
Why are the Right side wheels unable to be rotated by hand? Shouldn't they spin freely by hand?
The only thing I did recently was rotate wheels front to back and back to front for more even tire wear. Until I did this, all 4 wheels rotated while in 4 wheel drive mode.
The jack stands are not touching the wheels.
Are the Right side wheels locked for some reason? Why?
Any help in explaning this situationo is much appreciated.
fredty is offline   Reply With QuoteReply With Quote
Old 12-21-2023, 11:28 AM #2
Piggity Piggity is offline
Piggity will become famous soon enough
Most likely a seized caliper. Take the caliper off the brake rotor on the right side and see if you can spin the hub by hand.
Past: 06' Limited 4WD V6 Nautical Blue Metallic
265/65R18 Cooper A/TW tires with TT - 2018 Forest River 201BHXL
Present: 08' Tundra Limited
33" Duratrac, spacer Lift with TT - 2022 Keystone 252RD
Piggity is offline   Reply With QuoteReply With Quote
Old 12-21-2023, 05:23 PM #3
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Originally Posted by fredty View Post
hello,
Drive up the block. Are the wheels hot? Stuck brake caliper.. rears is stuck emergency brake shoes. Lube up the brake cables then never use the ebrake again for the rear. New caliper from AutoZone in front.
gaber6 is offline   Reply With QuoteReply With Quote
Old 12-21-2023, 05:28 PM #4
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
What's it do with the tranny in neutral?
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 12-21-2023, 06:56 PM #5
Wheels cannot be rotated in Park or Neutral.
The Parking Brake is not on.
Old 12-21-2023, 07:00 PM #6
Thank you to everyone who responded. I will take your suggestions on lubing the calipers and cables and try driving around to see if things loosen up.
Its just an odd coincidence that 2 wheels on the same side would lock up at the same time with no prior warning or symptoms.
I can see one wheel lock up and then another wheel lock up sometime later but 2 wheels lock up at the same time? Weird.
Old 12-22-2023, 04:44 PM #7
MikeinNH67's Avatar
MikeinNH67's Avatar
Easy to see if it's brake related or in the drivetrain. If brake it will not move at all and of course the wheels will get hot. If drivetrain, you would be able to rotate the wheel a bit because of the slight slop in the system.
Mike
03 4runner Limited
drive , hand , rotate , wheel , wheels
How often do you rotate your tires? Kanab Maintenance/Detailing 54 03-24-2020 10:17 PM
Should the wheels on a limited awd rotate freely... hoffmanmark 4th Gen T4Rs 8 09-30-2018 09:16 AM
how do *you* rotate your tires? 10JQKA Maintenance/Detailing 8 07-02-2013 10:06 PM
Quality and reliability go hand in hand Thai Off Topic 0 04-18-2003 03:54 PM
