Old 12-19-2023, 02:51 PM #1
ser182 ser182 is offline
ser182 is on a distinguished road
Replacing Shocks 04 Sport
I have an 04 sport with x-reas and I could not find a definitive answer in my question in the search.
Can I buy the none Xreas shocks to replace the old xreas? Im looking Bilstein 5100.
Or do I have to buy 5100 with xreas and not hook it up?
One other question. Do I have to also replace the springs?
If you any other advice please send it my way.
That for yall help.
ser182 is offline   Reply With QuoteReply With Quote
Old 12-19-2023, 03:08 PM #2
Hunter61 Hunter61 is offline
Real Name: Steven
Hunter61 will become famous soon enough
Real Name: Steven
The best thing to do is scrap the x-reas completely. I had a dealer quote me $4,000 to replace it and most indies won't touch it. The x-reas shocks & struts alone were $2,600 and just replacing the shocks and/or the struts is wasted cash if there's a leak in the system. And those prices were from several years ago and they're no doubt much higher now.
Hunter61 is offline   Reply With QuoteReply With Quote
Old 12-19-2023, 04:56 PM #3
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
From what I've read, I believe the shocks are connected via opposite corners so if you replace the fronts with normal assemblies you have to also replace the rears. The first thread seems to have some good info. The link after that is a sticky to all things suspension.
BTW, if you want a cheap route that will last the life of the car, just put used Gen 5 takeoffs on it. The ones I put on my truck were off a 6 month old Gen 5 runner that got lifted. All that is needed is a bit of trimming on the lower shock eyelet.
XREAS question
4th Gen Suspension Options/FAQ
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 12-19-2023, 09:06 PM #4
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I had xreas on mine and replaced with standard Bil 4600 {similar to 5100). I also chose to replace the springs with new '07 FJ springs, but not necessary. Once you remove your xreas shocks just pull off the rest of the system from the frame.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 12-20-2023, 09:29 AM #5
SandyDotson SandyDotson is offline
SandyDotson is on a distinguished road
Thanks for the advice, I appreciate it. I also would like to help you by sharing casinosanalyzer website link where you will find a lot of sites related to casino bankid through which you can make a lot of money while staying at home only. I am also using that website link to find online real-money gaming sites.
SandyDotson is offline   Reply With QuoteReply With Quote
Old 12-22-2023, 05:30 PM #6
4R005 4R005 is offline
4R005 is on a distinguished road
I had the xreas system in my ’05 4R Ltd/V8. One cross system line developed a leak from rust rendering it inoperative. Replacement components from the dealership were very pricey as noted by other members. To the best of my knowledge, no aftermarket replacement units were/are available. The OEM system is pressurized and
DYI installation can be difficult to ensure no pressure loss during the install.
I replaced the entire system with regular shocks, reusing the front springs which fitted nicely. The xreas OEM shocks cannot be reused.
If you also have the air suspension option, like mine, I’ll suggest you keep it ( if its still operational ). I kept mine. I believe the ride quality is better ( vs springs).
If you decide to junk the air suspension, you’ll have to remove the two air bladders over the rear axle and replace them with a pair of springs ( replacement kits available from auto parts stores ).
Yes, there was a slight leaning of the vehicle when rounding corners when compared with the xreas suspension, but not enough to be off putting IMO. Also depends on what shocks one decided to use. Bilsteins are popular and also $$.
4R005 is offline   Reply With QuoteReply With Quote
Old 12-22-2023, 05:35 PM #7
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
The suspension post linked in my sig should be helpful. You don’t have to replace the springs but you probably should.
Bluesky 07 is offline   Reply With QuoteReply With Quote
buy , question , replace , shocks , xreas
Replacing just shocks or more? VQDEK 3rd gen T4Rs 10 03-01-2021 02:03 PM
replacing shocks 90runnernj Classic T4Rs 4 12-02-2009 03:53 PM
Replacing Shocks - anything I need to know? vjr021 Classic T4Rs 2 05-05-2008 03:27 PM
Help Replacing Shocks goose17 Maintenance/Detailing 3 07-10-2007 08:22 PM
replacing shocks on 03' what should I get? ajjaaron Maintenance/Detailing 1 09-25-2006 08:24 AM
