Old 12-23-2023, 01:17 PM #1
robotfood540 robotfood540 is offline
robotfood540 is on a distinguished road
Electrical/Alternator Issue?
Hi All, recently my 2006 V8 Limited started making a strange rumbling sound from the passenger side dash, in addition to an electrical whine through the speakers. Even the electric brake booster noise was amplified. My first guess was a failing alternator; however, I think the issue may be related to the headunit. The headunit has begun to restart randomly and the speakers have also stopped working. Only when resetting the battery will the speakers power back on. Is this an electrical/grounding issue from the headunit or something else? Also by chance, my steering has begun to feel verrryy heavy. I'm not sure if the issues are related, or if the truck is just falling apart at once. I intend to flush the power steering fluid today and look at the intermediate shaft. Merry Christmas to me!
Thanks!
robotfood540 is offline   Reply With QuoteReply With Quote
Old 12-23-2023, 03:16 PM #2
d33pt d33pt is offline
d33pt is on a distinguished road
Thanks!
Pull the fuse for the headunit and see what happens. I think you have a bunch of issues all at once though. But just eliminate things one at a time.
d33pt is offline   Reply With QuoteReply With Quote
Old 12-26-2023, 03:16 PM #3
I pulled the two radio fuses and sure enough any rumbling and electrical noises disappeared, leading me to believe that there is some grounding issue with the head unit. I'm assuming something has just shaken loose and I'll be doing a deeper dive this week. I also hit the intermediate shaft u-joint with some WD-40 and that seems to have fixed (temporarily) the stiff steering issue.
Old 01-24-2024, 08:48 PM #4
Bringing this to the top...
When it rains it pours. Two weeks ago my car also went into limp mode and pulled a P2445 code (secondary air injection pump stuck open). I have a bypass kit so was lost as to why this happened. I pulled the negative battery terminal overnight, wiped the code, and voila! No issues in over 300 miles since....until...
Recently when putting the key into the ignition and trying to start, nothing happens! No crank (one click MAYBE), very dim to no power to accessories, etc. Yet, it would ultimately start after a few attempts. I checked the battery and it was still reading 12.6V when off. Based on some research I was lead to believe it might be a key/immobilizer issue. When I use the non-chipped key everything works fine?? Any ideas with this latest issue?
Old 01-24-2024, 11:07 PM #5
dirty monkey dirty monkey is offline
dirty monkey is on a distinguished road
Test your alternator.
How to Test a Toyota Collora Alternator is Good or Bad Using a Multi Meter - YouTube
TEST YOUR ALTERNATOR TO MAKE SURE IT’S GOOD. #shorts #youtubeshorts - YouTube
You also might have a bad alternator cable.check your terminals
dirty monkey is offline   Reply With QuoteReply With Quote
Old 01-25-2024, 05:46 PM #6
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
It doesn't make sense that it's immobilizer related if you are losing power. You read 12.6v at the battery but what about inside the car, like at the accessory plug, when the key is turned to start? You should have very little voltage drop between the battery and that plug. How do your battery terminals look? All 4 contact points should shine. This is my quick check for loose/dirty connections, turn the headlights on in a place you can see them, try to start the car while watching the lights. If they dim or go out but eventually come back after letting go of the key then you have a bad battery or bad connections somewhere. If you monitor with a meter that's on the battery at the same time (need a helper) and the voltage doesn't drop much then it's a connection somewhere, usually the battery terminals.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 01-26-2024, 03:43 PM #7
TY both above for the suggestions. I'll give them a go this weekend. Good news is we bought a new Grand Highlander so the pressure is off a little bit to get this sorted out.
Old 01-27-2024, 08:05 PM #8
glm97229's Avatar
glm97229 glm97229 is offline
glm97229 is on a distinguished road
glm97229's Avatar
Good ending to a headache for sure - I've been chasing a complete shutdown of the side and rear window defrost on my 1995 SR5 - For a long time -
glm97229 is offline   Reply With QuoteReply With Quote
begun , headunit , issue , related , speakers
Electrical Issue? Alternator? funkerama 4th Gen T4Rs 0 10-19-2021 03:47 PM
'96 Electrical (Likely Alternator) Issue tkc74 3rd gen T4Rs 6 07-17-2019 12:25 PM
Electrical Gurus Please Help. Overloaded/Squealing Alternator redrunn Classic T4Rs 6 07-07-2015 02:26 PM
Alternator Electrical Connector calrider 3rd gen T4Rs 3 03-27-2015 09:52 PM
Odd electrical or Alternator issues? Rommel 4th Gen T4Rs 3 06-08-2014 11:48 PM
