Old 12-26-2023, 12:05 PM #1
mooch91 mooch91 is offline
mooch91 is on a distinguished road
Hot rear brakes
Merry Christmas everyone. Over my holiday break, I'm going to try to straighten out a rear brake job which has kicked my @s$.
Long story short, I replaced:
  • rear pads
  • rear rotors
  • driver's rear caliper with hose
  • passenger parking brake shoes with hardware
  • brake fluid, properly bled
All parts NAPA. Hardest part of the job was the passenger parking brake because it got stuck coming off and required about 8 hours worth of work to remove it (posted about it here).
I'm getting high rotor temps in the rear, particularly on the passenger side. Fronts are less than 100 deg F, driver's rear gets up to about 150-200 deg F, and passenger rear is close to 300 deg F, all after a 15-minute ride. Passenger side has a bit of a "hot" odor, but nothing that smells particularly distinct.
My 5th gen stays at less than 100 deg F at each wheel for the same period of driving.
I had it cooler for a period of time by backing BOTH parking brakes off completely, but since then I have tightened up on the driver's side (at the wheel) and surprisingly the passenger side got hot again. I think this might have been a fluke and just something that happened disassembling and reassembling the whole setup. I've rebuilt the whole parking brake on the passenger side twice now. Everything seems to move freely in the parking brake on the passenger side when the piston is compressed, even when the parking brake is properly adjusted.
Last thing to try is a new hose and caliper for the passenger side, as it's about the only thing that hasn't been replaced. Piston seems to compress ok, and it does float on the slide pins well, but I can't guarantee it's not dragging slightly at times.
Anything else I might not be thinking to check which can cause warm or hot rear brakes?
Hot rear brakes-img_2115-jpg
2002 Sport V6 210K - sold
2006 SR5 V6 226K
2014 SR5 125K
2023 Limited 3000mi
mooch91 is offline   Reply With QuoteReply With Quote
Old 12-26-2023, 01:38 PM #2
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
Is it possible the Ebrake cable is seizing or binding? I'm not sure how it all works since I've not had a problem with it but maybe after you've adjusted everything, don't apply the Ebrake, just drive it around and see if you get the same temps. Then apply the Ebrake, release it and drive around again, same course, and see if you get higher temps.
I had an '89 Toyota pickup truck with an Ebrake that would literally freeze when it had been raining, then dropped below freezing. Rear wheels would get really hot. I quit using it when it was supposed to get cold. You could have dirt or even a pinched cable that's binding and causing your problem.
Also, under the console, aft of the shifter is an Ebrake adjuster. That may be set too tight also.
Just my 2¢
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 12-26-2023, 02:24 PM #3
SocalSam SocalSam is offline
SocalSam will become famous soon enough
If you have replaced everything and exhausted all possibilities, it's time to look at hydrobooster. My new to me 03 would pull hard to the right on medium to hard brake application but otherwise stopped OK. After a month, the pump failed so I replaced pump and accumulator (from the junkyard). Pull went away. Can't explain why this happened but it did. Also, I think there are screeen filters inside the hydroboost unit which if clogged that could cause fluid pressure to be incorrectly applied. I'm thinking rears are getting too much pressure which is causing them to heat up. Anyways, this is basis for research as I saw a YT video on this but can't find it now.
SocalSam is offline   Reply With QuoteReply With Quote
Old 12-26-2023, 04:47 PM #4
delz05 delz05 is offline
delz05 is on a distinguished road
I would re-check the E-brake setting...
06 4Runner Limited V8, 05 Tundra Stepside
16 Audi A8L, 13 Audi S5 Convertible
Family comes first....nice cars a close second!
delz05 is offline   Reply With QuoteReply With Quote
Old 12-28-2023, 06:05 PM #5
MikeinNH67's Avatar
MikeinNH67's Avatar
Just wondering why you started a new thread. Here's the original one if folks want more background.
Parking brake may not be right?
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 12-28-2023, 06:12 PM #6
Because I wasn't convinced it was the parking brake any more...
Replaced the last caliper today and re-adjusted both sides of the parking brake to 8 clicks. Temperatures at the back rotors are a little hotter than the front, but are now the same side-to-side.
I think it was the caliper, dragging just slightly. The parking brake was what you would call a "red herring" - it wasn't the problem I was chasing, just a coincidence that it started at the time I replaced it.
2006 SR5 V6 226K
2014 SR5 125K
2023 Limited 3000mi
brake , parking , passenger , rear , side
Rear Brakes nc-grayson 3rd gen T4Rs 14 11-27-2015 04:05 PM
So I almost got raped by the Dealer today....brakes brakes brakes. DizzyV6P 5th gen T4Rs 36 04-28-2015 11:23 PM
1999 4runner, Changed rear seals and still no rear brakes?? rmoore 3rd gen T4Rs 7 07-20-2011 09:24 PM
New rear brakes steved 4th Gen T4Rs 8 06-23-2007 11:30 AM
rear brakes hulk311 4th Gen T4Rs 0 05-28-2007 10:07 PM
