Old 12-27-2023, 03:03 PM #1
dbolin160 dbolin160 is offline
Real Name: Dena
dbolin160 is on a distinguished road
Real Name: Dena
Help with lower return line leak~!!!
I have 2004 T4R sport V8 4WD 4DR installed a new lower return line (amazon: A-Premium Power Steering Pressure Hose Line Assembly Compatible with Toyota 4Runner & Lexus GX470, 2003-2009, V8 4.7L, Replace for 3401235, 4441335010) and new air vacuum control (ebay: OEM# 17630-16040 FOR TOYOTA LEXUX VALVE ASSY, POWER STEERING AIR VACUUM CONTROL)
My only issue now is I can't get the driver side connection to quit leaking. Any suggestions?
Thanks,
Dena
dbolin160 is offline   Reply With QuoteReply With Quote
Old 12-27-2023, 09:34 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Isn't the PS return line just hose clamp? Is it a hose clamp you're having a problem with, or is it a hose with threaded fitting ?
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 12-28-2023, 01:12 AM #3
Real Name: Dena
Real Name: Dena
PS leak
Help with lower return line leak~!!!-powr-steering-pressure-hose-line-assembly-pic-jpg
Old 12-28-2023, 03:16 PM #4
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice Drcoffee is just really nice
Drcoffee's Avatar
If its truly the return line its not under pressure. Reinstall the old part and cut off the leaking section. Hose clamp a hose to the stub and rout it back to the res. But if its the pressure hose from pump tighten it a little more or return it.
2007 4Runner Sport 4WD 4.0L 228,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP…how’s it going for you now Trump is gone? Be careful what you ask for. You may just get it.
Drcoffee is offline   Reply With QuoteReply With Quote
Old 12-28-2023, 04:57 PM #5
MikeinNH67's Avatar
MikeinNH67's Avatar
Where exactly is it leaking?
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 12-28-2023, 06:13 PM #6
Drcoffee's Avatar
Drcoffee's Avatar
Check rockauto. You might have the wrong part for the return line. They show two parts; hose kit and rack connector.
Help with lower return line leak~!!!-img_4620-jpg
Old 12-30-2023, 04:19 PM #7
4R005 4R005 is offline
4R005 is on a distinguished road
Your pic shows a pressure line. The return line from rack to reservoir will have a threaded fitting to the rack ( driver side ) and hose clamp at the reservoir ( passenger side). If leak is at rack side, you may have cross threaded when installing fitting to rack ( apparently quite easy to do ). Hope its not the case here. Like others had mentioned the return line sees very little pressure, just head ( height difference between rack/reservoir ) and some line friction forces from rack to reservoir.
4R005 is offline   Reply With QuoteReply With Quote
Old 12-31-2023, 06:10 AM #8
Real Name: Dena
Real Name: Dena
Power steering
It’s the pressure hose then. The one with the threaded fitting on the drivers side. I can’t get it to thread at all now. I had it threaded, it leaked pretty bad so I thought I hadn’t done it right. Took it off the car to start all over again. Now I can’t get it to thread at all… so frustrating!! It’s at kind of a weird angle. I’m not sure what I’m doing wrong.
Help with lower return line leak~!!!-img_7203-jpg
Old 12-31-2023, 09:17 AM #9
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
You've probably got the thread in the steering rack boogered just a little and you're going to have to be lined up just right with right amount of pressure to get it started, it may take 20-30 minutes or more to get it going unless it's really damaged. Try turning the fitting in the loosening direction with a little pressure on it until you feel it "click, then try going tightening direction with a little pressure on it. I know what you're going through and it takes time and just the right combination.
Look closely at the threads on the fitting on the hose make sure they are not damaged on the very end, if they are take a fine file and try and smooth them out.
Old 01-01-2024, 10:35 AM #10
If following @rdruss instructions were a no go, you may want to try this. Instead of trying to thread the new hose’s fitting into the rack, cut off the fitting from the old hose and try again with @rdruss ’s procedure. Lining up the old fitting w/o the hose is much easier to get the two components to line up dead straight.
If all the above fail, you’ll need to beg, borrow or rent a tap & die set to chase the threads of the rack and the new fitting. Hopefully there is space to accommodate the tap when fixing the threads in the rack. Also need a telescopic pen magnet, or similar to clean out any metal debris from rack. It’s a delicate operation, so lots of patience required and do not rush.
Lots of luck to you and hope that all ends well.
Worse case scenario will be a rack & pinion removal to fix the threads in the rack.
Old 01-02-2024, 04:38 PM #11
MikeinNH67's Avatar
MikeinNH67's Avatar
Good replies above. One thing to note whenever doing these types of connections, try turning the steel line a bit to see if it's loose after installing. When tight it will not move at all. If it moves it will leak.
Also, if the threads look messed up on the new line you may just want to get another and try again. You should never put a wrench on it until you can spin it on by hand at least a full turn. Hopefully the threads on the line are softer than the rack ones.
Mike
03 4runner Limited
air , line , steering , toyota , vacuum
Power Steering Leak...lower return line MountainsRcalling 4th Gen T4Rs 39 12-27-2023 02:23 PM
Power Steering Lower Return Hose Leak davidaw 4th Gen T4Rs 15 02-27-2023 11:43 PM
which ATF "front" oil cooler line is the return line to the tranny? keakar 4th Gen T4Rs 5 11-12-2017 07:59 PM
Help Please. which tranny line is the return? Limbwalker 3rd gen T4Rs 5 10-11-2014 07:48 PM
Dry Fuel Return Line eddyrios Classic T4Rs 2 11-01-2011 08:45 AM
