Old 12-27-2023, 10:23 PM #1
8355adam 8355adam is offline
8355adam is on a distinguished road
Will this rim/tire combination rub?
Canít seem to find divinities answer anywhere. So here goesÖ
I would to know if TRD pro wheels with 265/70/17 tires will rub on a 2005 SR5 with dobinson 2inch front and 1.5 inch rear lift. Can I go bigger than 32inch?
I canít figure out the offset difference plus the lift difference vs stock and what that will do for the rubbing. Iím just trying to get the best biggest tire combo for the lift I have with nicer wheels
98' SR5, 5MT, OME springs, HD shocks, 299's, Shrockwerks Bumper
2013 - BMW M3 (E90) ZHC
2004 - BMW 330i (E46) ZHP
8355adam is offline   Reply With QuoteReply With Quote
Old 12-27-2023, 11:52 PM #2
dfontes's Avatar
dfontes dfontes is offline
dfontes is on a distinguished road
dfontes's Avatar
Originally Posted by 8355adam View Post
Can’t seem to find divinities answer anywhere. So here goes…
I can’t figure out the offset difference plus the lift difference vs stock and what that will do for the rubbing. I’m just trying to get the best biggest tire combo for the lift I have with nicer wheels
You should have very minimal rubbing with that setup. I currently have 265/70-17s on stock wheels and occasionally have very slight rubbing on the front passenger fender liner.
The biggest you can safely go with your setup is 275/70-17 if you hardcore off road often, or 285-70-17 if you don't hardcore off road often. Both setups will require you to move the fender liners slightly forward to avoid rubbing, which is easy. With the 285 tire you might need to chop the body mount if you do hardcore off-roading.
I'll be installing 17x8, 0 offset wheels, with 285/70-17 tires. I found that wheels that are 8.5" wide or less with 0 offset and 285/70-17 tires is the biggest you can go while having the best chance to not chop the body mount. Wheels that are negative offset tend to cause more rubbing.
dfontes is offline   Reply With QuoteReply With Quote
canít , difference , lift , rub , wheels
Moab bound:deciding which wheel tire combination to take Orlyg1521 Off-Roading 8 07-26-2014 06:48 PM
combination switch Kel Varnsen Classic T4Rs 2 09-25-2013 06:23 PM
2005 Lift/Spacer/Tire Combination 4runnerIdaho 4th Gen T4Rs 6 11-30-2012 01:53 AM
Yes, combination questions. tbst Engines / Suspension / Wheels / Tires / Audio / Accessories 3 12-19-2011 04:40 PM
best tire for combination of grip/tread life? 4Runner_mudder 3rd gen T4Rs 31 03-22-2010 04:50 PM
