Old 05-24-2024, 10:31 AM #31
locked up's Avatar
locked up locked up is offline
locked up is on a distinguished road
locked up's Avatar
Unfortunately, on the way to Krawltex I noticed that it was running hot.
I was running a Bluetooth code scanner with live data.
So I brought it from one shop to another... back to Bearden Automotive.
Since they just did a bunch of engine work I just want to make sure it's not something they did.
Bearden traced it to the Radiator.
Said it looked like the PO had used some stop leak and it probably clogged it up. This explains the overheating that PO mentioned.
It had hot & cold spots so that got replaced along with the cap. Pretty happy to have this sorted out.
Locked Up's 4Runner-img_5355-jpg
locked up is offline   Reply With QuoteReply With Quote
Old 05-24-2024, 10:32 AM #32
locked up's Avatar
locked up's Avatar
While it was there I asked them about the no heat on the Passenger side that I had noticed last winter and forgot about.
They poked around and said the Air Mix servo isn't working so I will order one of those after I verify. Hopefully that is it and nothing to do with a clogged heater core from the dang stop leak used by PO.
Additional shot of Engine bay because I forgot to post after I added the new intake assembly and new MAF so here they are.
And the passenger front turn signal went out and was causing the fast blink.
So swapped this out too.
Locked Up's 4Runner-img_5356-jpg  Locked Up's 4Runner-img_5357-jpg
Old 08-08-2024, 10:57 PM #33
locked up's Avatar
locked up's Avatar
2 super exciting updates:
New gas cap and purge solenoid.
I know.
I'm excited too...
Had a P0442 code and it was just the gas cap, but I had already ordered the solenoid so on it goes.
Fun stuff coming tomorrow.
Locked Up's 4Runner-img_5615-jpg  Locked Up's 4Runner-img_5690-jpg
Old 08-09-2024, 05:37 PM #34
locked up's Avatar
locked up's Avatar
Got most of the front end redone....
8/9/2024
216,253
Powerstop Front Pads & Rotors - Amazon
Powerstop Rear Pads & Rotors - Amazon
VastAuto Hub Grease Caps - Amazon
Detroit Driver Front Wheel Bearing - Amazon
Geometry Correction UCAs - SuperPro
LCA Kit - SuperPro
Sway bar Drop - Amazon
Dobinsons 1-3.5" IMS Coilovers (+100lbs/black) - Exit Offroad
Dobinsons C59-675V Variable Long travel coils (black) - Exit Offroad
Dobinsons IMS59-50701 Shocks - Exit Offroad
Extended Stainless Kevlar Teflon (maybe some Unobtanium too) Brake lines Front & Rear (smoked black) - YotaMafia
OEM 5th Gen CV Axles (43430-60082) - Joe Joe
OEM Differential Mounts lower x2 - Partsourq
OEM Differential Mounts upper x2 - Partsourq
OEM Support assy front diff (5238060012) - Partsourq
OEM Support assy front diff (5238060021) - Partsourq
Alignment and install of above parts - Krawltex Motorsports
I opted for the 3.5" setting and extra 100lbs because I have a winch & bumper planned ... but it is sitting too high.
I get some nice vibrations under acceleration and when turning.
So, I think I will try to lower the front this weekend about 1" to let it settle in.
After the winch/bumper I will adjust it back up if need be.
Before the Dobinsons My front measurements were ~22" hub center to fender and rear was ~23".
Now they are all around 24".
Locked Up's 4Runner-img_5693-jpg  Locked Up's 4Runner-img_5694-jpg  Locked Up's 4Runner-img_5695-jpg  Locked Up's 4Runner-img_5698-jpg  Locked Up's 4Runner-img_5699-jpg  Locked Up's 4Runner-document-5-jpg
4wd , front , jeep , lift , rid
Manual Locked 4Runner Value? edelm 3rd gen T4Rs 26 11-18-2016 12:11 PM
FS: 3rd gen 4Runner SAS, Locked, Armored $15,500 obo SoCal KinevilsT4R For Sale: Vehicles 21 07-31-2016 04:21 PM
Locked vs. Double Locked The Battle of the Capables 4Running Daily 3rd gen T4Rs 19 01-27-2014 12:38 AM
keys locked in 4runner ncjeyota Classic T4Rs 8 03-25-2013 07:51 PM
