Old 01-04-2024, 01:44 AM #1
joshik joshik is offline
joshik will become famous soon enough
Routing wire from starter battery to house battery
I am planning to run some heavy awg wire from my engine bay to my house battery in the rear cargo area (area where sub used to be). I have a Renogy DC DC charge controller back there w my house battery. I'm trying to decide if I should run wire from the engine bay thru the firewall along the door trim to the back or run it on the outside by the frame (tucked away) and come up through the running board light grommet.
Thoughts? Anything wrong w running it inside the entire length? I'll be charging at 40amps. I will of course have the proper safety measures. Proper fuses. Correct awg wire. Etc.
2003 4Runner Limited 4wd V8. JBA UCA, Dobinsons MRA Front Coilovers, Dobinsons MRA Long Travel rear. Cooper AT3 XLT 285/70R17
91 Ext Cab 4x4 Yota, black with 4" front IFS trailmaster lift, 3" Downey rear springs, Downey Rubicon extended shackles, and 2" body lift. 35" BFG M/T w/ 4.56. Centerforce II clutch, Rancho 5000s all around and Rancho traction bar, K&N Air filter, Flowmaster, ARB Rear Diff Air Locker, Custom "Mad Eyes" light covers, Extended Diff Breathers, Hella Vision Plus Headlights. [SOLD]
joshik is offline   Reply With QuoteReply With Quote
Old 01-04-2024, 03:34 PM #2
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
Ran through the firewall to a DCDC charger. There a grommet on the driverside. Didn’t like the idea of heavy gauge wire exploited to the elements/potential road debris
'08 Silver SR5 V6 4x4: OEM+
Berty_K is offline   Reply With QuoteReply With Quote
Old 01-04-2024, 05:33 PM #3
yeh i thought of the debris and stuff too but i figured tucked up and out of the way with some sheath would be pretty good.
Running it inside seems easier though.
area , battery , house , run , wire
LiFePO4 house battery with 270XP alternator 4RExplorer 5th gen T4Rs 5 11-04-2019 07:04 PM
Charging a LiFePO4 house battery from alternator 4RExplorer 5th gen T4Rs 7 05-14-2019 09:39 PM
Linked house battery and fuse box setup Porrick 5th gen T4Rs 4 04-03-2018 10:46 AM
Starter Battery: How many CCA do we REALLY need? Bumbo 4th Gen T4Rs 7 03-13-2017 09:09 PM
Battery questions. What size wire for battery? 2 gauge enough? e60ral 5th gen T4Rs 9 03-12-2017 12:29 PM
