Old 01-24-2024, 01:42 PM #16
SkilletLiquor's Avatar
SkilletLiquor SkilletLiquor is offline
SkilletLiquor is on a distinguished road
Originally Posted by dirty monkey View Post
The V6 Actuators are a lot easier, you only have to worry about one rod. With the V8 Actuators there are two rods, one for the Center lock and 4lo. how do i know, well watched a bunch of youtube vids showing how easy it is to fix the leak. Yeah no, Do not take out the actuator, I broke a Teeth in the actuator. There is a Timing on the actuators, if you dont get them correct, it wont work. Best way is just to remove the Transfer case, disassemble and replace.
for V8 Aisin part SAT003
That makes sense. I've been down that same YT rabbit hole of late and was having a tough time figuring out why some actuators appear to have a single rod and others have two. I've got a V6, so I feel a bit less trepidation about messing with it now. Just have to steal the rig back from my snowboarding son for a day or two.
2008 4Runner SR5 - Beige Budget Build (Bilstein 5100s, SPC UCAs, Goodyear Wrangler Workhorse AT)
SkilletLiquor is offline   Reply With QuoteReply With Quote
Old 01-24-2024, 07:03 PM #17
Tony2Tugs Tony2Tugs is offline
Tony2Tugs is on a distinguished road
You've got it backwards. The V6 actuator has 2 rods. The replacement for the V6 is more complicated due to having to drop and split the transfer case in order to remove the actuator. The V6 actuator rods have locking pins within the transfer case that make it impossible to remove without splitting the TC. The V8 actuator is removable without dropping the TC but you need to be careful not to damage the actuator seals when doing it.
I've done this repair twice since the first Dorman actuator I purchased was faulty. The 2nd one worked and has been fine for about 6 months. I have a V6 btw. If I could go back in time, I would buy the AISIN actuator instead. You live and you learn.
Tony2Tugs is offline   Reply With QuoteReply With Quote
Old 01-24-2024, 11:27 PM #18
dirty monkey dirty monkey is offline
dirty monkey is on a distinguished road
So What that would mean is that you have a Center diff lock. with Center diff lock, you will have 2 rod actuator.
What you are refering to as being easy, is people without a center diff lock.
dirty monkey is offline   Reply With QuoteReply With Quote
Old 01-25-2024, 10:45 PM #19
This vid might be enlightening for the V8 crowd:
4Runner Asian SAT-003 4WD Actuator Replacement Full Video 36410-60093 - YouTube
Last edited by SkilletLiquor; 01-25-2024 at 10:47 PM. Reason: youtube link got horked
Old 02-09-2024, 07:05 PM #20
psamvks psamvks is offline
psamvks is on a distinguished road
Just replaced front acutuator (bench tested working), still no 4wd
I just got an 04 V6 sport that wont go into 4wd. No matter where I put the selector, or push the diff lock button, nothing happens. ( neutral for 4lo ) On the dash, the center diff lock light is always on, the green 4wd light blinks slowly, the VSC TRAC and VSC OFF lights are solid on. I have let it sit overnight with the battery disconnected then preformed the zero point reset. I replaced the front actuator with a confirmed working one, and confirmed that the ring moves freely. When 4Hi is selected I am not getting any power to the front actuator. The center actuator moves when power is applied to both sets of pins. but I have not confirmed that power is making it to this actuator from the vehicle. I took apart and cleaned the contacts of the selector switch, and it is in working order. I am at a loss. Do i throw in a new control unit? or start checking wire continuity? If anyone has experienced this issue before, any help would be much appreciate, thanks!!!
[/IMG]
psamvks is offline   Reply With QuoteReply With Quote
4wd , actuator , aftermarket , difference , oem
Door Actuator or Fob Issue? (One Actuator Already Replaced) Mlynn 4th Gen T4Rs 6 06-28-2022 12:02 PM
Preventative maintenance for front diff actuator and/or center diff lock actuator NJ-4Runner 3rd gen T4Rs 12 04-22-2021 11:26 PM
4th Gen Actuator, Help! SHagood 4th Gen T4Rs 11 01-22-2020 11:08 AM
FREE!! Wiring harness for aftermarket radio with aftermarket amp fblainen11 3rd gen T4Rs 4 01-30-2019 05:16 PM
4Lo actuator faqoldschool 4th Gen T4Rs 6 09-23-2012 12:12 AM
