Old 01-04-2024, 04:47 PM #1
zguy1's Avatar
zguy1 zguy1 is offline
zguy1 has a spectacular aura about zguy1 has a spectacular aura about
zguy1's Avatar
Rust starting around rear hatch window...
Hello. I noticed some bubbling starting in the paint on the top of my rear window a few months ago. It is spreading fast. I would like to eliminate or stop it.
What are my options to do so? If it needs to be a body shop, I am not concerned about spraying the whole hatch as opposed to them just doing a spot repair.
Thoughts?
[IMG][/IMG]
[IMG][/IMG]
zguy1 is offline   Reply With QuoteReply With Quote
Old 01-04-2024, 07:37 PM #2
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Yep, thatll happen
so you could either go body shop or do it yourself in a weekend
Youll want to remove the weather stripping and sand down any areas that you see rust. At this point doesnt look like youll need body filler.
Id recommend a rust converter to apply after you sand it down. Probably will work better with the paint if you use a gray like corroseal as opposed to a black one like rustoleum rust converter
Youll then have to paint and blend.
May need to be touched up from time to time
concerned , hatch , rear , starting , window
paint bubble / rear hatch rust swerks 4th Gen T4Rs 4 01-10-2021 05:52 PM
Rust bleeding through paint on rear hatch whiskywizard 5th gen T4Rs 64 10-02-2020 04:44 PM
Best way to prevent rear hatch rust from spreading? nobb 3rd gen T4Rs 8 04-08-2019 05:08 PM
Rear differential rust and rear wheel axle starting to leak Boognish_Forever 3rd gen T4Rs 14 12-03-2018 04:38 PM
Rear hatch struts rust nighthawk 3rd gen T4Rs 6 03-03-2010 02:23 PM
