Old 01-06-2024, 11:15 AM #1
KBToys KBToys is offline
KBToys is on a distinguished road
Emergency brake hitting stud
I recently had the e-brake hardware replaced, and now one of the wheel stud heads is hitting the top hat on the e-brake. Anybody have a similar issue, not too sure what to do
KBToys is offline   Reply With QuoteReply With Quote
Old 01-06-2024, 06:54 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Someone recently had the same issue when they replaced their hardware with aftermarket hardware, it seems that some aftermarket hardware isn't an exact match to the OEM hardware and thusly can hit the back of the wheel studs.
2004 Limited V8
Old 01-07-2024, 12:51 PM #3
luckyluke luckyluke is offline
Real Name: Lucas
luckyluke is on a distinguished road
Real Name: Lucas
Is it an aftermarket brake shoe issue?
I'm about to replace it too. Did you take pictures by chance? What aftermarket shoes you got? I was thinking about TRWs and they are ~10 times less expensive then OEM.
2007 SR5 4x4 V6. Bilsteins 5100 all around. Front set to 1.75. Daystar spacers 1.5 in the rear. Stock springs. Cooper Discoverers A/T3 265/75R16.
luckyluke is offline   Reply With QuoteReply With Quote
Old 01-07-2024, 11:07 PM #4
The brake shoes were fine it was the hardware that rusted apart, mainly the pins inside the springs
Old 01-08-2024, 11:06 AM #5
inscarguy's Avatar
inscarguy inscarguy is offline
Real Name: brian
inscarguy has a spectacular aura about inscarguy has a spectacular aura about
inscarguy's Avatar
Real Name: brian
The guy who had the issue was me. I tried 3 aftermarket companies for hardware with no luck( Carlson, Raybestos, Wagner ). The issue is the holddown pins are close to 1mm too long. It does not pull the cup down far enough and hits the hub. You have to get the OEM pins and cups for it to work correctly.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
inscarguy is offline   Reply With QuoteReply With Quote
Old 01-08-2024, 02:20 PM #6
Thank-you, I did use an aftermarket napa hardware kit. I thought something wasn't installed correctly, but the aftermarket parts makes sense
Old 01-08-2024, 05:12 PM #7
MikeinNH67's Avatar
MikeinNH67's Avatar
I had it happen on the one that's bent. I put something solid on the back of the pin and gave the cup side a whack or two to bring the C bend in a bit. If it's the other side, you could add a washer to the back side to shim it out.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 01-11-2024, 02:39 PM #8
Real Name: Lucas
Real Name: Lucas
There is some aftermarket Carmont kit TOY-00358-P (FB-11-04-C) that has the correct pins, but it is missing horse washers and the the bottom springs and the cap washer with bent end.
I had to mix it with the other set with wrong pins.
e-brake , hitting , issue , similar , stud
Emergency brake - “they all do that” TRDrew 5th gen T4Rs 26 05-10-2021 10:01 AM
Parking Brake / Emergency Brake Question Woz1976-MT 5th gen T4Rs 5 04-21-2018 05:52 PM
Emergency brake HELP 1998 Runner 3rd gen T4Rs 2 03-01-2015 02:43 PM
Sound when hitting brake in REVERSE Ant General Discussions 5 08-27-2008 05:57 PM
emergency brake gonzo 4th Gen T4Rs 5 10-10-2004 07:36 AM
