Old 01-06-2024, 01:08 PM #1
mrshanno mrshanno is offline
mrshanno is on a distinguished road
Wetness on carpet in rear corner near hatchback door
Hi,
I noticed the carpet is wet on the passenger side corner (only) near the rear hatchback (see picture). The metal underneath and corner tie down area does not appear to be wet. It did "bleed" wetness up to the shelf which I typically keep in the down position.
Any thoughts on where this could be coming from? The weather stripping at the rear hatchback door all appears to be in good shape. No wetness from the ceiling that I can see.
Thanks!
Wetness on carpet in rear corner near hatchback door-attach0_20240106_121810-jpg
mrshanno is offline   Reply With QuoteReply With Quote
Old 01-08-2024, 05:20 PM #2
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
How's the horizontal weather strip at the bottom of the hatch window? That one has a tendency to rot away and allow excess water into the hatch which can spill inside. Also check the hatch drain points at the bottom of the door. The way it's setup, it really shouldn't get water that far in but water can be tricky.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 01-09-2024, 11:37 PM #3
Ida4runner Ida4runner is offline
Ida4runner will become famous soon enough
Mine drips in from the top of the door/hatch, doesn't happen always and I haven't looked at it yet, maybe the weather stripping?
Ida4runner is offline   Reply With QuoteReply With Quote
Old 01-11-2024, 07:16 PM #4
4Runnergenius 4Runnergenius is offline
Real Name: Chris
4Runnergenius is on a distinguished road
Real Name: Chris
i vote on the weatherstrip..
4Runnergenius is offline   Reply With QuoteReply With Quote
Old 01-14-2024, 04:59 AM #5
CZ75 CZ75 is offline
CZ75 is on a distinguished road
I've had a leak for years and thought it was coming from the bolts that hold the roof rack on so I used silicone on those bolts. It helped a lot, but now I'm thinking the moon roof is leaking and the water runs down a channel in the roof to the rear. Sometimes see water spots on the inside of the passenger side rear window.
It leaks on the passenger side where yours does when the truck it parked uphill. The plastic pocket in the corner gets wet. When parked downhill there's a puddle on the drivers floor mat. I can hear water sloshing around overhead and maybe a drain tube is clogged from leaves/debris. Haven't taken the moon roof apart to investigate yet.
AKA: Blowout
CZ75 is offline   Reply With QuoteReply With Quote
corner , door , hatchback , rear , wetness
door panels,fenders,rear bumper,carpet for my 95 alljackedup Want to Buy/Trade 1 04-14-2014 11:49 PM
Need some guidance- leak at hatchback? sakoluvr 3rd gen T4Rs 6 12-19-2013 08:36 AM
FS: 3rd gen Corner lamps and brown door handles. toyofreak For Sale: T4R Items 1 06-07-2012 02:20 PM
rear door carpet 810moto 4th Gen T4Rs 19 05-19-2011 01:48 AM
04 4runner hatchback electrical problem? mdabrows 4th Gen T4Rs 14 07-18-2010 12:57 PM
