03-13-2024, 08:06 PM
Oxygen Sensor question
Once I replace the bad O2 sensors, do i need to use the scanner to clear the codes to see if it worked, or will the codes clear once I fire the care up on their own? Thx.
03-14-2024, 11:57 AM
the answer is yes! Do pay attention to the quality and TYPE of O2 sensors that're going back into the engine. Amazon has lots of knock off Denso products. Also, pre-cat vs post-cat sensors may have different part numbers. Pre-cat sensors are often known as "air fuel ratio" sensors.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
03-20-2024, 01:16 PM
O2 sensor update/frustration
Had the two upstream sensors replaced with correct Denso from Rock Auto. The engine light is gone, but the VSC and Trac Off persist. When i start the car up its off, but as soon as i drive it, it goes on and stays on. I used the scanner and it shows no error codes. Gas cap good, MAF sensor cleaned. No vacuum leaks. Car seems to run fine.
So, what do I do?
Thanks.
03-20-2024, 04:37 PM
the VSC & TRAC OFF lights are typically triggered when there's a CEL . Since your CEL is off, I wonder if there are codes still in the memory? You may not be able to pull those error codes w/o using a more sophisticated reader, like Techstream.
03-20-2024, 07:13 PM
If it's just those 2 lights, I would try the zero point calibration you can do. Check it out in the stickies section. Older code readers can mess it up which will make the lights go on.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
03-20-2024, 08:53 PM
oxy sensor question
My mechanic put the o2 sensors in because one i got under the car and saw the limited access, I paid the $$ to have it done.
The VSC and Track Off lights came on once i start driving, not at idle when first starting car. But, later that day, the engine light came back on.
I did that reset thing a few years ago when this happened, but i did not have the engine light on,
My mechanic is supposed to use a more sophisticated scanner tomorrow. I guess i'll see. I did not have any codes show when i got home and used my cheap scan tool. But then the engine warning light returned. Pretty confusing.
03-30-2024, 02:50 PM
Update: So, after the two upstream O2 sensors were replaced, I was still getting the error codes. I did the zero point callibration with no change. Then I did a complete battery disconnect, let it sit for 10 minutes with the headlights on to drain the circuits and reconnected. Everything gone! I was excited until after 200 miles, the check engine, VSC and Track off lights returned.
I pulled out my cheap scanner and I got the P0174: system too lean for bank 2, P0171: system too lean bank 1 and another P0174 system too lean Bank 2. I don't know what to do. Vacuum leak test passed according to scanner. The new O2 sensors are Denso.
As an aside, anyone recommend a user friendly, resonably priced scanner that would help diagnose the problem? Thx.
03-30-2024, 05:18 PM
If it's running lean, could it be a problem with your fuel system? Maybe the injectors are clogged?
03-30-2024, 05:25 PM
Real Name: Skip
Real Name: Skip
How did you determine the gas cap is still good?
Unless it's new and OEM I would replace it with a new OEM cap, aftermarket caps are hit and miss with sealing properly, also make sure the metal gas filler neck sealing surface is sooth and clean.
I had the same lights come on and replaced my old cap with a new OEM cap and the lights went off on their own within 30 or so miles on my drive home.
2004 Limited V8
03-30-2024, 06:47 PM
She seems to be running okay. I periodically use Berryl Chem tool in it.
She seems to be running okay. I periodically use Beryman Chem tool in it.
03-30-2024, 06:48 PM
I cleaned the cap and filler neck. I lubed the gasket. A new cap is like $50 now from toyota. I'll have to see if anything else pops up.
03-30-2024, 08:00 PM
Real Name: Skip
Real Name: Skip
You need to check with another dealer, that dealer is trying to rip you off!!
I paid less than $25 for mine, full retail is about $32.
Toyota Gas Cap - Guaranteed Genuine from ToyotaPartsDeal.com)
2004 Limited V8
03-31-2024, 04:58 PM
Thanks. I rechecked and you were correct. I just ordered it for the same price locally, so no shipping. I'll give it a go and report back. Thanks.
04-03-2024, 02:09 PM
Installed the factory gas cap, drove over 30 miles and no change. All the same warning lights are on. Now what?
