Old 02-12-2024, 02:52 AM #1
MrSeth's Avatar
MrSeth MrSeth is offline
Real Name: Seth
MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough MrSeth is a jewel in the rough
MrSeth's Avatar
Real Name: Seth
Smile Renology Aux Battery
Hey team, I recently completed my "entry level" auxiliary battery setup on my 2006 V6 4R. It runs my little F40C4TMP fridge on Eco-Mode (35w off and on) for the time I need it to as well as charging my cell phone and insulin pump controller device.
I do have a Bluetti EB3A, but it discharges in about 5.5-6 hours and takes about 3-4 hours to recharge while driving via the cigarette lighter. The bigger and better units go up in price really quickly, and I wanted something to be more "stock" looking and for it to be able to stay in the truck at all times.
Battery: Renology 12v 100ah/10HR Deepcyle AGM
Isolator: Keyline 12v 140 Amp kit (comes with wires to connect the two batteries)
Cutoff Switches: Ampper Battery Switch 12-48V Master Cutoff
Fuse Block (in trunk): 6 fuse, 12v, ATC/ATO block.
Power Accessory Panel: Kohree 12v Marine Car Charger Socket Panel
Accessory panel wired to fuse block using 10g wire (no temp change while running fridge)
Renology wired to fuse block using 6g
Cutoff switches between two batteries and between Renology and fuse block
Pictures:
Renology
Renology
Renology
Untitled
Untitled
Note: I figure I'll need something from redarc if I wanted to charge with solar and/or upgrade to lithium ion in the future, but running the AGM just charging off the main battery seems to be doing just fine! I am assuming that with a charger I could probably get the AGM up past 13V resting (?) but we will see. I was super pleased having the charge only drop from 12.8-12.9V down to 12.6-12.7V after having my things run on it for about 10 hours.
2006 Shadow Mica SR5 v6
1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
MrSeth is offline   Reply With QuoteReply With Quote
12v , battery , block , fuse , renology
Battery voltage dropping randomly after new alternator, battery and serpentine belt almostbasic 5th gen T4Rs 11 07-10-2023 11:00 PM
Exact battery cable lengths for OME replacement with OEM battery oriented posts. Majindan 3rd gen T4Rs 3 11-20-2017 02:57 PM
Anyone using the $26 Summit Racing SUM-G1201 battery tray for 31M battery? jicko 5th gen T4Rs 3 04-27-2015 12:24 PM
Multi Battery Isolator and Dual Battery Selector, $60 - Pocatello, ID tjhaf2007 For Sale: Non-T4R Items 17 10-16-2013 11:00 PM
SS006-07 08/11/2007 Battery - Absorbed Glass Mat Battery (AGM) Information CBR_GUY_IA TSB 0 07-12-2009 09:30 PM
