Old 01-18-2024, 12:42 PM #1
GCEMSPETE GCEMSPETE is offline
GCEMSPETE is on a distinguished road
04 Limited with X-REAS suspension replacement
Hey all,
I've got a 04 Limited V8 with 213k. It's been riding bouncier lately so I've been researching suspension replacement. I don't wish to raise the runner up and I am planning on upgrading my calipers and rotors to a Gen 5 since I'm having sticking issues.
My runner has the X-REAS suspension and I've read different things. From what I gather in can just disconnect the X-REAS lines from the suspension and replace with Bilstein 5100? Also do I need to replace the springs if they look solid?
Thanks for any info!
GCEMSPETE is offline   Reply With QuoteReply With Quote
Old 01-18-2024, 01:25 PM #2
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
I have an '04 V8 SE. When/if my X-REAS wear out I plan on getting them replaced, if OEM parts are available. I tow a 23' Airstream (about 6,500 lbs) and the X-REAS have performed very well for both ride and handling.
I understand the desire to change if you have a spongy ride but have you considered taking it to a Toyota dealership to have them checked? Maybe there's just a fluid leak and it needs to be repaired and fluid replaced. Just a thought - 2¢
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 01-18-2024, 02:27 PM #3
I have not taken it to the dealership cause I was trying to just do things myself. Since my mileage is so high I just assumed the suspension would need to be replaced anyway.
Old 01-18-2024, 04:46 PM #4
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
Grab assemblies if possible. I put new/used (6 month old) gen5 assemblies on the front of mine. Got back to normal lift and way better ride over the old assemblies. Cheap way out for an old vehicle.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 01-18-2024, 08:39 PM #5
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I replaced mine with Bilstein 4600's and FJ springs. Your stock springs will be ok as long as they are in good condition, but they may have sagged a little. The 4600's offer a firmer ride, less nose dive and less body roll when cornering. The Bilstiens in general are a little harsh over small road bumps.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 01-19-2024, 02:53 AM #6
Rocket3004 Rocket3004 is offline
Rocket3004 is on a distinguished road
Interesting. Was there a way to assure they were removed in the proper way so that there was no fluid lost?
Did you replace the 4 shocks only or did you also replace the center controllers as well? If you could share any and all details that would be great! A lot of folks are yanking out their new-like new 5th gen units and this would be a great (and likely affordable) way to replace the tired 4th gen units!
Rocket3004 is offline   Reply With QuoteReply With Quote
Old 01-19-2024, 07:51 AM #7
What do you mean by assemblies?
Old 01-19-2024, 07:59 AM #8
Mind giving a link or telling what year FJ springs you used?
Old 01-19-2024, 08:59 AM #9
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I used '07 FJ springs; P/N 48231-35321
Old 01-19-2024, 09:03 AM #10
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Let me be more specific:
Rear springs: 48231-35321
Front springs: 48131-35541 and 48131-35551
All for an '07 FJ.
Old 01-19-2024, 09:09 AM #11
OopsIBrokeIt OopsIBrokeIt is offline
OopsIBrokeIt will become famous soon enough
Hey all,
X-REAS isn't bad, just prohibitively expensive to repair since so many bits all have to come from the dealer and get replaced together. If you want to replace it, just unbolt everything and install new shocks.
1. Replace everything F/R simultaneously. Once you've loosened/removed one X-REAS shock the opposite corner loses pressure too, so it's all or nothing.
2. Springs are optional, though recommended. I replaced everything around 250k and discovered my 1.5" lift was more like 3" over the current ride height. Turns out my factory springs were so worn that they were sagging several inches from where they were supposed to be.
3. Don't forget new top hats with the new shock, as well as inspecting the various bushings and ball joints. Replacing suspension components is cheapest when you already have things unbolted & need an alignment anyway.
OopsIBrokeIt is offline   Reply With QuoteReply With Quote
Old 01-19-2024, 09:22 AM #12
I'm assuming any 07 FJ spring would work off RockAuto? Also, what made you decide to replace the springs? What should I look for in mine?
Old 01-19-2024, 10:05 AM #13
All for an '07 FJ.
Is there a specific reason you went to FJ springs instead of just 4runner springs?
Old 01-19-2024, 04:25 PM #14
MikeinNH67's Avatar
MikeinNH67's Avatar
Sorry, I should have been more specific. These are the standard assembly with spring, strut and top hat. My truck doesn't have X-reas just giving another option as I understand repairing this system is pricey. Something like the link below. I was watching for them and found some that were on a Gen5 truck for 6 months. They had the same year stamped on them and looked brand new. All you have to do is trim the lower eyelet about 1MM and they fit right on. I see some that come with the rear shocks too.
https://www.ebay.com/itm/14550947521...wAAOSwkFtlgjbM
Mike
03 4runner Limited
Old 01-19-2024, 09:58 PM #15
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
At the time (2016) the FJ springs were being promoted in discussions on here as the way to go and that's why I chose them. Haven't been sorry, although the Bils are a little harsh on road bumps so I have new Dobinson IMS in hand that I will install once the weather turns warmer, they are progressive valved vs. Bils being digressive valved, so I expect a little better road ride.
limited , replace , runner , suspension , x-reas
Replace X-REAS suspension without removing X-REAS Fareastplaza Maintenance/Detailing 20 05-10-2024 08:42 AM
2013 Limited 4X4 suspension replacement options dclark2171 5th gen T4Rs 6 08-17-2021 02:30 AM
Replacement suspension to bypass X-REAS- stock height only! nalbertasr5 4th Gen T4Rs 4 06-07-2017 04:51 PM
X-REAS suspension replacement on 2007 sport edition walterlaughlin General Discussions 3 01-04-2015 12:08 AM
X-REAS suspension in the limited freezy74 4th Gen T4Rs 20 06-14-2006 10:15 AM
