Old 01-19-2024, 10:22 PM #1
airbur's Avatar
airbur airbur is offline
airbur is an unknown quantity at this point
airbur's Avatar
Front Axle Nut Thread Sizing
Howdy. I have an OEM 2004 Toyota 4Runner v8 front axle that I just rebooted. It was in storage so I don't have the original nut. I bought new OEM axle nuts (from Toyota) and they do not fit. Were different sizes of nuts used? I also have an aftermarket axle and the OEM nuts fit it perfectly. What is the thread size so I can try chasing them with a die? Thanks.
Axle Nut: 90178-28002 - Axle Nut 1995-2023 Toyota | Fred Haas Toyota Parts
airbur is offline   Reply With QuoteReply With Quote
Old 01-20-2024, 09:06 AM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Chasing the threads with a die won't make a nut fit that isn't the right size, something wrong in your situation.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 01-20-2024, 09:08 AM #3
airbur's Avatar
airbur's Avatar
Considering the new OEM nut fits on an aftermarket axle that we're replacing, I can only assume the threads on the OEM axle have been damaged.
Old 01-23-2024, 10:08 AM #4
airbur's Avatar
airbur's Avatar
Resolved!
Took the axle up to CVG Axles in Denver and they corrected the threads. Size is M28x1.5. Worked perfectly and the OEM nuts fit again.
axle , front , nuts , oem , toyota
Rear Axle Seals: The Ultimate Information and Replacement Thread (3rd gen) BigFishAllDay 3rd gen T4Rs 581 02-28-2024 08:37 PM
Another Rear Axle Leak Thread brian4t 3rd gen T4Rs 16 05-11-2016 12:57 AM
CV Axle Thread Repair flyinbrick 3rd gen T4Rs 7 09-04-2015 11:39 AM
Rear axle seals / Differential: Best gear lube thread Drcoffee 3rd gen T4Rs 7 05-01-2012 06:08 PM
