Old 01-21-2024, 03:46 AM #1
othompson824 othompson824 is offline
Real Name: Owen
othompson824 is on a distinguished road
Real Name: Owen
p0420, p0430, and p0456 idk what to do
On my 2006 4runner V6...
Hey guys so for while now i've had a CEL. The first time I took it to autozone i got these codes: p0420, p0430, and p0456. After some research i found an exhaust leak could be the issue. And a couple months ago I took it to a muffler shop to put a flowmaster muffler on so I thought there might be a leak from that. So my buddy and I took off the cat back and there was, in fact, a couple leaks where the new muffler was attached. We welded them up and put it back together. Then i unplugged the battery to reset everything and drove for a couple days and they came back on. Took it to autozone and the exact same codes still. So i'm not sure if its an o2 sensor, still a leak somewhere, or worst case scenario gotta replace my cats.
Any ideas?
Couple things that may be worth noting i've replaced both the rear exhaust gaskets within the past couple months and only intake mod i've done is a charcoal filter delete
Also the p0456 - we've had this one before and replaced the gas cap and it was off for a while but now back on so not sure what it could be either, more concerned about the cats though
othompson824 is offline   Reply With QuoteReply With Quote
Old 01-22-2024, 05:04 AM #2
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
Any ideas?
p0456 is gas cap related....replace with new gas cap and clear lights.
p0430 and po420 are related to the downstream oxygen sensors....either remove them , soak and wash with toilet cleaner or add spacers to the sensors..if emission testing isnt needed in your location
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 01-22-2024, 06:02 PM #3
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
Any ideas?
Your profile says "Folsom" - is that Folsom, CA? If this is the case, you won't be able to use spacers or any other inexpensive emissions fooling tricks on the internet as the smog anything will fail anything which does not pass visual and does not have the monitors set on the ECU. Your options are to replace the worn out cats with new cats (p0420/p0430 indicate cats are worn or missing) or try something different.
I have been working on a drop-in modified o2 sensor which appears to be a normal o2 sensor from the outside, but it outputs conditioned signals which advise the computer that the catalytic converters are working normally. I have them in my truck and have been experimenting with their signal levels for months (I had the same o2 codes you do), if you want to buy a pair of them and install them into your truck, let me know.
thank you
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
back , couple , leak , muffler , p0456
P0420 & P0430 Codes olalekanbabs 4th Gen T4Rs 26 09-03-2020 04:35 PM
P0420, P0430 and O2 simulator alia176 4th Gen T4Rs 1 07-20-2016 11:46 AM
CEL 2 codes P0420 P0430 kacper 4th Gen T4Rs 6 11-20-2014 04:13 PM
P0420 & p0430 4derekyrunner 4th Gen T4Rs 3 02-26-2012 11:49 AM
P0430 and P0420 at the same time! Runner4u Problems & Warranty Issues 7 12-09-2010 12:49 AM
