Replace the PCV for $20 and 5min of time...oil is cheaper than a RMS and there's honestly no "good" reason to repair a small leak if you only drive it that much each year...just keep clean oil in it and do your routine maintenance check-ins and it won't cost you much...again, the PCV is an easy swap to piece of mind...they do clog and the typical first place you might notice a seep/leak is the RMS...
https://www.ebay.com/itm/153054862566
Use a 22mm deep socket or a 7/8 O2 sensor socket and the swap is easy!
