Old 01-23-2024, 02:39 PM #1
parsky1 parsky1 is offline
parsky1 is on a distinguished road
2005 v8 4wd 5100 kit selection
I have a 2005 V8 4wd 4Runner with stock suspension. I would like a slight lift but still have a bit of rake to the front, maybe 1”. I don’t want to go over 2” because I don’t want new control arms or a diff drop, etc. Any recommendations for a 5100 kit with the correct springs? I’m trying to get a better understanding of the OME springs. It currently measures 33” in the front and 34.75” in the back to top of wheel well on the outside. I would prefer a quick strut.
Was also contemplating the KVB quick struts but I don’t think that will get me there.
parsky1 is offline   Reply With QuoteReply With Quote
Old 01-23-2024, 03:38 PM #2
Syr4RinNC's Avatar
Syr4RinNC's Avatar
What is your primary reason for wanting the lift? Just the suspension is worn and want to get a little higher when replaced? Planning on bigger tires? Planning on off-roading?
Old 01-23-2024, 04:15 PM #3
188k on it now. Factory suspension is shot. P265/65/r17 on it now. I just think it would look better with a bit more lift. I might go up a tire size when these are shot.
Old 01-24-2024, 09:02 PM #4
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
i agree, it will look better with a slight lift whether you are planning for any other mods or not. I went with 4600s, '07 FJ springs and a 1/2" spacer in the front. The 5100s would eliminate the need for the front spacer.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 01-25-2024, 09:57 AM #5
I’m thinking 5100s all around. For the front OME2884 and the Toytec super flex RCC2.0-P in the rear. I thought about the OME2895E but it’s quite a bit stiffer. Having a hard time figuring out how this will all sit with the v8. I want to put BFG265/70/r17 on it and not have it rub at all. A positive rake is fine. For sure no more than factory rake.
Old 01-29-2024, 05:11 PM #6
Alright. I’m thinking a more modest lift. Thinking OME 2883 (883) and wheeler T12 in the rear with 5100s all around. Looks like the wheeler T1 would work in the front. I think any taller will look dumb with 265/70/r17s. Plus I’m hoping the shorter lift keeps me out of needing new upper control arms.
Old 01-30-2024, 02:19 AM #7
stevelikesrhino stevelikesrhino is offline
stevelikesrhino is on a distinguished road
Best option is to get 4 corner 5100 only and set it at 0.85 setting (second notch from bottom) and assemble the strut yourself. KYB strut top is dirt cheap and you can get it at Autozone, and then you can rent a spring compressor. Plus, this way you don't need to get the trim packer to adjust the port side lean because OEM springs accomodate the lean already. You don't need to wait for lift to settle to get an alignment either, since your 20 year-old springs are more than settled. You will get a German car like plush ride, while having better handling. Literally best option.
I have 2883 with dobinson C59-505, and 5100s. I feel like 5100s are really designed to use with stock springs, even the 220 lb/in rear coils are too stiff. I can imagine with stock springs the ride must be wonderful.
Preload itself doesn't make it ride worse, it's the increase control arm angle.
stevelikesrhino is offline   Reply With QuoteReply With Quote
4wd , don’t , front , quick , springs
5100 rear shock for 2005+ Tacoma HiluxSurf SSR-G 3rd gen T4Rs 3 03-26-2021 05:46 PM
5100 Install 885 Front Superflex Rear 2005 V8 DASYOTA 4th Gen T4Rs 4 10-06-2020 09:04 AM
5th Gen Speaker Selection KP Texan 5th gen T4Rs 10 10-05-2019 09:40 PM
Help regarding 4th Gen selection? Bye bye to 5th? tacobill 4th Gen T4Rs 14 03-13-2013 03:02 AM
GPS Selection - PLEASE HELP!!! frankhead Engines / Suspension / Wheels / Tires / Audio / Accessories 3 10-13-2007 07:55 PM
