Old 01-28-2024, 12:51 PM #1
airbur's Avatar
airbur airbur is offline
airbur is an unknown quantity at this point
airbur's Avatar
Auto Door Lock Question
I searched but couldn't find this exact issue. 2003 V8 Sport....when the ignition key is turned from ON to ACC (door remains closed) all the doors unlock. I've reviewed the instructions in the manual multiple times and this isn't even a function it mentions...let alone how to program/cancel it. Has nothing to do with the gear lever position etc. I'd like the doors to remain locked when the key is moved from ON to ACC. Any suggestions?
Thanks!
airbur is offline   Reply With QuoteReply With Quote
Old 01-29-2024, 09:22 AM #2
OopsIBrokeIt OopsIBrokeIt is offline
OopsIBrokeIt will become famous soon enough
This is entirely speculation, but:
https://www.toyota-4runner.org/474439-post5.html
Maybe you have option D set there, and a less than fully functional door sensor? If the driver's door sensor was intermittently showing open, even for a fraction of a second it'd probably unlock once the key position was changed.
OopsIBrokeIt is offline   Reply With QuoteReply With Quote
Old 01-29-2024, 09:43 AM #3
airbur's Avatar
airbur's Avatar
Thanks for the idea. I also thought of that and checked the functionality of the cabin light turning on and off with the door and that seems to work fine. I'm sure it couldn't hurt to replace the sensor.
Old 01-29-2024, 11:27 AM #4
SocalSam SocalSam is offline
SocalSam will become famous soon enough
This. I'm thinking option B is closer to what the OP wants.
SocalSam is offline   Reply With QuoteReply With Quote
Old 01-29-2024, 11:28 AM #5
airbur's Avatar
airbur's Avatar
Actually, no. I don't want anything to happen with shift lever position or ignition key position.
Old 01-29-2024, 01:23 PM #6
Look at the last sentence in the manual attachment a few posts above. The lock behavior can be toggled on and off.
Old 01-29-2024, 01:45 PM #7
airbur's Avatar
airbur's Avatar
Nope...you can only toggle something off that has a process to be turned on. There is no process shown to turn it on in the first place.
Old 01-29-2024, 01:57 PM #8
Sigh. Read it again. Or read it for the first time.
Old 02-04-2024, 10:13 PM #9
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
Thanks!
I'd suggest checking if there's any aftermarket alarm or keyless entry system installed. Sometimes these systems have their own quirky behaviors.
If that's not the case, it might be worth taking a peek under the hood (figuratively speaking) – check the wiring around the ignition switch and the door lock system. A loose connection or a worn-out wire could be causing this mystery unlock.
weberlukas74 is offline   Reply With QuoteReply With Quote
acc , door , doors , key , program/cancel
Auto door lock on a manual? 5VZ-FE 3rd gen T4Rs 0 01-30-2022 02:07 AM
Trying to turn off auto door lock drftingfromshor 4th Gen T4Rs 8 05-11-2021 02:28 PM
Disable Auto Door Lock? UTEP 3rd gen T4Rs 6 02-18-2015 05:43 PM
96 auto door lock Gonzo113 3rd gen T4Rs 3 07-12-2011 02:46 AM
2002 Auto door lock shock003 3rd gen T4Rs 3 12-03-2004 05:07 AM
