01-28-2024, 09:34 PM
TPMS with Real Time PSI
Hello everyone,
Recently added a 2007 4Runner SR5.
Really been enjoying this platform.
Have a question in regards to the TPMS.
Right now I am only alerted when tire pressure is low.
From what I have read, the factory Toyota TPMS (42607-33021) operate on 315Mhz.
Is there a way read the actual tire pressure of each tire while inside the cab?
I have seen these kits on Amazon that replace the TPMS internally or these little external tire caps that then transmit to a display inside the cab that is either hard wired or plugged into the cigarette lighter.
Does anyone use a reliable system that gives real time tire pressure?
Thanks in advance :-)
01-29-2024, 10:58 AM
Real Name: Rich
Real Name: Rich
There are after market TPMS systems, mostly for trailers. They are either the valve stem cap type or actual unit mounted in the wheel. They have a display screen inside the tow vehicle that monitors the pressure and temp of the tires. This is mostly because when pulling a trailer, especially travel trailers, if you have a blowout on a tandem axle trailer it will do tremendous damage to the trailer and the driver wouldn't even know it. The panel will tell you when the tire is overheating or pressure has dropped so you can pull over and take care of it.
If you go this route you would need to disable the OEM TPMS or you'll have a light indicating a problem. I'm not sure if having a second system would interfere with one another.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
01-31-2024, 02:39 PM
Originally Posted by patch4r
Hello everyone,
I added a Kenwood headunit into mine with iDataLink Maestro. With this setup I can monitor the realtime TPMS readout per wheel on the headunit. There's a ton of other useful stuff in there too like MAF, battery voltage, instantaneous MPGs, etc.
I highly recommend it.
2008 SR5 | Build Thread
2006 AutoX Camry | Build Thread
01-31-2024, 02:47 PM
My 05 Gen4 TPMI never worked properly, so count yourself fortunate. I ultimately bypassed it as that light drove my OCD crazy. Not much help, i'm afraid, but at least you have an option if the system goes nutz like mine did a few years back
01-31-2024, 05:15 PM
My 07 Sport, with Pioneer NEX, and iDatalink Maestro displays OBD2 and TPMS PSI/Temps. Crutchfield.com
2007 T4R Sport V8 4WD, 145K, Seat Warmers, Pioneer NEX
2007 T4R Limited V8, 4WD, 181K, OME 2"
2014 GX 460 Premium
1997 FZJ80 OME 2.5"
2006 T4R Limited V8 - R.I.P.
02-02-2024, 08:13 AM
Real Name: brian
Real Name: brian
Another neat feature of the Maestro is if you get a CEL, it comes up on the radio and it will tell you what it is and you can also clear it out.
It also tells you the spare PSI.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
02-02-2024, 10:01 AM
toyota techstream can give you live data. do you need it though for your use? you can do alot with the techstream software.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
02-02-2024, 10:29 AM
maestro would be probably be the way to go for other added benefits.. it wouldn't read for me anyway since I'm on aftermarket beadlock wheels, so this is what I'm currently running.. Amazon.com
It's a recent install but seems to be working decent so far. I'll need to see how accurate the reading is, though ultimately, as long as it's uniform I don't care if it's reading higher or lower.
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
02-04-2024, 10:53 PM
Some great ideas, thank you.
Ultimately I want to find something that will read from the factory 315MHz Toyota TPMS that will give me the actual PSI in the cab.
I want to stay away from the value stem caps if at all possible, but those would be my last resort because I want to keep it simple.
I found a few on amzn but they only read TPMS at 433MHz which I believe will not work.
02-07-2024, 08:59 AM
another option is the ScanGaugeii obdii reader. I would search it up a bit, but from what i've seen they read TPMS from toyota in psi (along with a number of other potentially useful obdii readings)
02-08-2024, 03:47 AM
Real Name: SuinaEnurlSF
Have you considered the iDataLink Maestro system for monitoring real-time TPMS data on your 2007 4Runner, or do you have specific requirements that make other options more suitable?
02-09-2024, 02:41 AM
Saw something like this pic on amzn…..
Just a simple way to have real time tire pressure in the cab of the 4Runner.
Anyone have experience using this item or something similar in the picture?
Would much rather have the sensor internal verse the external valve stem caps.
02-09-2024, 10:16 AM
Real Name: Rich
Real Name: Rich
Can you share the link?
Rich
Kentucky
02-09-2024, 05:25 PM
02-10-2024, 11:11 AM
Real Name: Rich
Real Name: Rich
No reviews so I would avoid this product.
The description says to attach to the valve stem, but the picture shows TPMS sensors that need to be installed.
Your Denso sensors operate at 315 Mhz but it looks like these operate at 433.92
If you swap out for different sensors you'll need to disable the OEM system.
If you want to go ahead you should contact the seller for more details.
Rich
Kentucky
