Old 04-14-2017, 07:49 PM #1
4genrunner 4genrunner is offline
4genrunner is on a distinguished road
Clunking on driver side over bumps?
So I keep getting this clunking over bumps. It sounds like it's on the drivers side and I can feel a clunk in the floor through my foot every now and again. It doesn't matter if I hit a bump on the driver or passenger side it does it. I replaced the away bar links as they were worn. But still clunking. No noticeable looseness in the wheel with the vehicle in the air. I had a mechanic take a look at it and I believe he checked control arms and ball joints while the vehicle was jacked up on the control arm itself and no luck. Idk where this is coming from but it's a annoying
4genrunner is offline   Reply With QuoteReply With Quote
Old 04-14-2017, 07:55 PM #2
Forgot to mention the cv axle boots on both sides are torn. Maybe the driver side axle makes this noise? Doesn't click what so ever though. Would this make noise even if the passenger side hits a bump?
Old 04-14-2017, 08:41 PM #3
banilla16's Avatar
banilla16 banilla16 is offline
banilla16 is on a distinguished road
banilla16's Avatar
Could be a lot of things. Could be your cv, suspension, sway bar (bushing), end link (bushing), spare tire holder....
Priority is to get those cv boots fixed.
2003 Toyota 4Runner Sport - "Dumbo"
2018 Toyota Camry- "Sylvie"
banilla16 is offline   Reply With QuoteReply With Quote
Old 04-14-2017, 09:00 PM #4
Sway bar end links are new. I'm going to try doing the sway bar bushings on the frame because they arent too expensive. And see if I can get it back in the air and check further
Old 04-17-2017, 06:29 PM #5
Any other suggestions. Goes into shop tomorrow
Old 04-18-2017, 05:46 AM #6
3rdrail00 3rdrail00 is offline
3rdrail00 is on a distinguished road
Sway Bar Frame Bushings. Same thing happened on mine. Cheap, easy fix and stopped the clunking.
Bone Stock '08 SR5.
Give me time.
3rdrail00 is offline   Reply With QuoteReply With Quote
Old 04-18-2017, 09:55 AM #7
brianhuntRVA's Avatar
brianhuntRVA brianhuntRVA is offline
brianhuntRVA is on a distinguished road
I will agree on sway bar bushings as a good guess. I was able to grab my sway bar and move it around enough to recreate my clunk. I was afraid to snap a rusty bolt so I had a shop change mine when it was inspected. They said they didn't think they needed to be changed but I told them to do it anyway. No more clunking.
03 Sport v8, HCF delete, K&N air filter, Front: FJ KYB StrutPlus w/ 1" spacer, Rear: KYB w/ 1.5" spacer, Cooper Adventurer AT 265/70/17, black headlights/taillights
brianhuntRVA is offline   Reply With QuoteReply With Quote
Old 04-18-2017, 01:15 PM #8
4Runner010's Avatar
4Runner010 4Runner010 is offline
Real Name: Summit
4Runner010 is on a distinguished road
4Runner010's Avatar
Real Name: Summit
Check at full droop to see if your UCA are hitting your coils. Mine do
2003 Build thread http://www.toyota-4runner.org/4th-ge...ld-thread.html
4Runner010 is offline   Reply With QuoteReply With Quote
Old 04-18-2017, 01:16 PM #9
vastano vastano is offline
vastano is on a distinguished road
3rd (or 4th) for sway bar bushings, very simple 5-10 minute fix.
vastano is offline   Reply With QuoteReply With Quote
Old 04-18-2017, 03:07 PM #10
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
well, what's the verdict?
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 04-18-2017, 04:13 PM #11
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
OJ is NOT GUILTY!!!! hahaha. Sorry, been watching that show on Netflix this week.
OP, did you change your struts out recently? Maybe forgot a washer in the correct position around the top hat? That happened to me recently when someone else assembled some struts for me.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 04-18-2017, 04:37 PM #12
You funny dude, LOL!!
That reminds me, I need to get going on ordering a set of springs for my 80 from your outfit.....one of these days......SIGH
Old 04-19-2017, 07:36 AM #13
cyber_ecco cyber_ecco is offline
cyber_ecco is on a distinguished road
Had same problem over a year ago. Replaced sway bar bushings and went away. Recently it came back again. Re greased the bushings and its quiet again.
cyber_ecco is offline   Reply With QuoteReply With Quote
Old 04-19-2017, 09:04 AM #14
kcdehart's Avatar
kcdehart kcdehart is offline
Real Name: Kevin
kcdehart is a jewel in the rough kcdehart is a jewel in the rough kcdehart is a jewel in the rough kcdehart is a jewel in the rough
kcdehart's Avatar
Real Name: Kevin
Grab the CV and wiggle it. Does it make the clunk?
My truck has been clunking on the driver's side for a while, I finally got under it and poked around and found that the CV's are wiggling/clunking all over the place on both sides. Zero of the usual CV clicking symptoms. Replacing them this evening. I'll let you know if the clunk goes away.
'04 4Runner - Build Thread | '05 CBR 600RR & 1000RR - The slow vehicles ;)
kcdehart is offline   Reply With QuoteReply With Quote
Old 04-19-2017, 11:33 AM #15
I'm curious about this as well as I didn't think an intact CV would make audible clonks when going over bumps. If they do, I'd think they're broken at one end or the other. But, if they were broken, then you'd get the clicking sounds.
Clunking sound with light side to side movement after in rear after 3" lift BXPhoto 3rd gen T4Rs 1 11-24-2016 11:53 PM
Driver's Side Window - Clunking Fix Fletch888 4th Gen T4Rs 3 08-25-2015 07:07 PM
Clank noise coming from driver's side over bumps nysimonsez Problems & Warranty Issues 7 09-07-2011 01:35 PM
Clunking front suspension noises on bumps 4runningaround 4th Gen T4Rs 0 11-10-2008 02:54 AM
Clanking sound on driver's side when driving over bumps beeran 4th Gen T4Rs 6 02-07-2005 06:51 PM
