Old 02-10-2024, 01:19 PM #1
locked up's Avatar
locked up locked up is offline
locked up is on a distinguished road
locked up's Avatar
Replaced 1x o2 sensor. 4 dives later I got CEL with P0174
V8
I replaced Bank 2 sensor 1 about 2 weeks ago because I had a code.
I think that was P0420 but I don't recall exactly.
I've only driven it a few times since then. 2x 1 mile trips. 2x 10 mile trips. On the last trip I got a CEL. So I pull codes and found multiple that I did not see before I changed the o2 sensor.
I also changed the radiator fan clutch and some coil packs if that matters.
I did feel like it was running a little rough at idle on drive 4 after I noticed the CEL but I didn't notice this at start up.
I did not notice that on drives 1, 2 or 3 but wasn't looking for it either (and 2 were so short).
Did not notice exhaust smell but didn't walk behind it while running.
Would go sniff it right now but it's storming.
A few internet suggestions were:
-Replace all the o2 sensors (the other 3) or at least the other front side front sensor.
-Clean the MAF sensor
-Replace/clean Fuel Injectors
-Clean TB
-Oil Filler Cap
-Gas Cap
Any other ideas?
Seeing as how mine popped up right after I changed 1 sensor, I am leaning towards it being an imbalance in the other sensors.
So I am ordering those but they won't be here until the 19th. Ugh!
EDIT: Found a few similar threads I am linking here that I am still reading through.
Some of the above ideas are echoed in these:
P0174, Rough Idle & Strong Exhaust Smell
Help needed- Fuel pressure test persistent p0174
P0174
Replaced 1x o2 sensor. 4 dives later I got CEL with P0174-426489772_10160879042260520_2378826148117426521_n-jpg
locked up is offline   Reply With QuoteReply With Quote
Old 02-10-2024, 11:56 PM #2
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Mine at 230k miles had the recurring code.
Yes, it helps to replace all the stated maintenance items, but finally when I replaced the cats, I think the culprit was the exhaust donuts slightly leaking. Hardly even noticable in the car, but likely the culprit to the codes.
Worth checking and or replacing
gaber6 is offline   Reply With QuoteReply With Quote
Old 02-12-2024, 10:04 AM #3
locked up's Avatar
locked up's Avatar
Ahhh. OK.
Did you go with OEM cats?
If not, what did you get?
EDIT:
I'm looking on RockAuto and a little confused.
Do we just have the 2 cats that are integrated with the manifolds or is there a 3rd one?
Looks like there is a 3rd...
Not sure how the system checks that because don't we have 4 o2 sensors ... one in front of and on behind the integrated cats?
So how does it know if that is even in place?
Old 02-13-2024, 09:34 AM #4
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
the catalytic converters in question are the 2 integrated into the exhaust manifold.
If you have an exhaust leak up top where the upper O2 (Air fuel) sensor is reading it's possible that is the cause.
failed/failing cat will read throw a code for a system below efficiency code (which is also common for a bad lower o2 sensor).
To answer your question on why it took driving around is because before a fault code is logged it goes through a few cycles to make sure the reading it was seeing wasn't an anomaly, not to mention it probably likely that you pulled the battery when doing this work? If so, that would have reset your system and it needs to go through a few driving cycles to reinitiate itself.
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
aemravan is offline   Reply With QuoteReply With Quote
Old 02-18-2024, 06:20 PM #5
I got the $400 per manifold cats. Don't know if they were any different but I didn't want the cheapest ones.
That may not have been the issue despite replacing them as there was a slight exhaust leak just before the O2 sensor.. so yea
Easy enough to do the donuts and even manifold to head gaskets first and save $800
mile , replace , replaced , sensor , trips
Replaced Plugs - Now I have a cam position sensor CEL FourGunner 5th gen T4Rs 5 06-13-2021 12:17 PM
Knock Sensor 0330 with everything replaced...puzzled Rock_Rat 3rd gen T4Rs 12 01-21-2015 09:34 AM
Replaced O2 Sensor - Still have Check Eng Light noiwontsmile Engines / Suspension / Wheels / Tires / Audio / Accessories 2 10-23-2014 11:59 PM
Pipe Assy. Replaced, Now o2 Sensor Screwed SMEE 4th Gen T4Rs 0 07-28-2011 05:00 PM
Replaced the Knock sensor and didn't solve my code 52 Pioneerof2003 Classic T4Rs 1 12-19-2010 06:29 PM
