Old 01-03-2016, 11:47 PM #1
Wile.E.Coyote Wile.E.Coyote is offline
Wile.E.Coyote is on a distinguished road
Clunking in reverse, where to start
I changed a lot of things at once, so I don't know where to start. Just looking for suggestions on where I should start looking.
I have a deep clunk in reverse only. Sounds like it's coming from the rear, but can't be sure. Seems to happen with each tire rotation, but also can't be sure. 2004 V6 4x4, 105k.
I recently did all of the following:
FJ springs all around with Bilstein 5100's set at .85.
Powerstop slotted and drilled rotors with pads all around.
New front calipers.
Greased all the zerks I could find in the driveline.
My mechanic seemed to think Ujoints. Suggestions?
Wile.E.Coyote is offline   Reply With QuoteReply With Quote
Old 01-04-2016, 12:02 AM #2
Onefastchevy Onefastchevy is offline
Onefastchevy is on a distinguished road
Yep. U joints are letting go. At least that is my bet. Now there is "slop" in the drive line.
Onefastchevy is offline   Reply With QuoteReply With Quote
Old 01-04-2016, 11:08 AM #3
Alright, I'll start the thread search.......
Thanks.
Old 01-04-2016, 12:14 PM #4
fdbyrne fdbyrne is offline
fdbyrne is on a distinguished road
I'd be surprised if it was a u-joint based on the description of the symptoms. A u-joint can clunk when there is slack in the driveline or when shifting from drive to reverse or reverse to drive but it doesn't often clunk while there is tension in the system like there would be while moving in reverse. Also, the drive shaft spins 3.5 to 4 times for every single revolution of the tire so it would clunk multiple times with every tire rotation.
My bet is on the brakes somehow since they were replaced right at the time when this started happening.
Since it's not full-time 4x4, why not lift the rear off the ground, chock the front tires, start it up, put it in reverse and let the engine idle spin the rear wheels. It should be pretty easy to tell where the sound is coming from.
2004 SR5 4x4 V6 - With New Head Gaskets
fdbyrne is offline   Reply With QuoteReply With Quote
Old 01-05-2016, 01:12 PM #5
I like that idea. I'll do it this weekend, thanks.
Old 01-29-2016, 10:56 PM #6
So I put it up last weekend and guess what? No noise when in reverse. Still does it when backing out of my driveway. Would u-joints have play that I'd be able to feel by pulling by hand? Or would it be too small to notice by hand?
Old 01-29-2016, 11:30 PM #7
The u-joints may be bad enough to feel the slop by hand, but they may not. When mine went bad, I just had a driveline vibration but couldn't fell any slop by hand.
You could probably pull the rear driveshaft off and drive it around the neighborhood in 4HI letting the front wheels do all the pushing and find out real quick whether it's the u-joints on the rear driveshaft. If the noise goes away it'll be pretty definitive that the u-joints are bad. If the noise persists you can be pretty certain that they're not causing the problem.
Our vehicles are pretty smart and it may figure out that the rear wheels aren't getting power and try to do something with the traction control. If so, you could probably lock the differential and be OK. If you do that, I'd only back it out of the driveway and pull it back in a few times. That should tell you what you need to know without messing anything up.
Old 01-30-2016, 12:11 AM #8
Thanks man, that's good brainin'.
Old 01-30-2016, 01:37 PM #9
Drunner97's Avatar
Drunner97 Drunner97 is offline
Real Name: Danny
Drunner97 will become famous soon enough Drunner97 will become famous soon enough
Drunner97's Avatar
Real Name: Danny
Could also just pull the plug on the Master to disable VSC/ABS/TRAC if going this route.
That being said, did you put the clips in the brake pads that keep them from moving? Could just be the pads shifting around. Also, since you just lifted, make sure you loosen/retorque all the bolts on the rear control arms and lateral bar. Otherwise those are still torqued down for stock suspension and can make noise. Might as well check your sway bar bushings while you're at it.
build thread: https://independentoffroading.com/in...xit-thread.30/
IG: @4runner_doa
Drunner97 is offline   Reply With QuoteReply With Quote
Old 02-01-2016, 01:09 PM #10
norrisbiker's Avatar
norrisbiker norrisbiker is offline
norrisbiker is on a distinguished road
I do not have a 4th gen, but looking to maybe buy one.
Do the rear driveshafts on these have a slip joint?
If so, that is also a possibility for the noise.
When the joint does not have enough grease in it, it can bind, then slip, creating the clunk/jerk, etc. when going from forward to reverse and the other way. It can also create the same issues when just going forward under load after going backwards.
It is a common problem on many 4WD pickups. I have had it on my 2009 Superduty.
If it has a zerk fitting, the fix is easy. If it does not, the driveshaft needs to be dropped so you can get at the splines and grease them.
Still looking for a 3rd/4th gen 4Runner
"I have often regretted my speech, never my silence" (Publilius Syrus - ~100BC)
norrisbiker is offline   Reply With QuoteReply With Quote
Old 02-01-2016, 01:28 PM #11
I admit to not being an expert but Yes, there is a zerk for greasing the u-joints and then another which I assume is for the slip joint. I've had the truck about a year and I didn't grease it until I did all the other work that I mentioned last month and the interesting part is that the clunk started AFTER I greased the driveline. I wasn't sure how much to grease the slip joint because I couldn't see where it would push any grease out so I just did maybe a dozen pumps and stopped. Not sure this is helpful info. I'm heading into the shop for some other work tomorrow and I'm just gunna have them take a look.
Old 02-01-2016, 01:52 PM #12
When I grease the slip joint, I pump grease into it until I see the drive shaft start to expand under the pressure of the new grease. I do this while it's sitting on the ground with weight on all four wheels. Then, I unscrew the zerk fitting and let the built up pressure push any overfill out the hole where the zerk was so that nothing is under pressure. That has always worked for me.
I wouldn't assume that the prior owner lubed the lube points as often as necessary. It may have been bone dry. If so, it would likely take more than a dozen pumps from the grease gun to fill the joint.
Old 02-01-2016, 01:55 PM #13
I definitely think the PO did not grease. It's good to know the proper procedure and I'm going to do that this weekend but it's unclear that it would cause my issue. Why would it be quiet when bone dry then bind once I added grease?
Old 02-01-2016, 02:02 PM #14
CAN-03runner's Avatar
CAN-03runner CAN-03runner is offline
CAN-03runner is on a distinguished road
What year is the truck. does it have the older style wheels or newer model.
Verify the lug nuts and make sure they are tight, or remove the wheel, put it back on and tighten up the nuts by hand with a torque wrench don't rely on when an air gun stops. I've experienced this, and another local toyota club memeber too. Both were after the wheels had been off for some work.
I've never had an issue with older style sport wheels, but I do with the FJ Cruiser wheels with the nuts seeming like they are torqued all the way, but really they are not.
Look at the rear drive shaft, and check if it is hitting the gas tank skid.
Rear 3rd dust shield also rotates, if it is bent it might be pushed in, in reverse and rub and make a sound and pulled when going forward so it doesn't rub and make a sound.
Pull the backing plate out, it might be rubbing, it may have been bent when the wheels were removed and reinstalled.
Look at the rear parking brake shoes.
Look at the control arm bushings.
2003 4Runner Sport 4.7 V8 Silver/Grey - Fr/Rr ARB Locker - OME 885/895 - LR UCA - BFG KM2 255/80/17- RCI Skids - Demello Sliders - Bud Hidden Winch- Runva Winch - Synthetic oils- Trail Stripes - Two Baby Seats...
1984/86 4runner In Progress....... V6 swap - High Steer - 33" MTZ - 4.88 Gears - welded rear - ARB front - axle gaussets - Diff covers - Longfields - 4.7 crawler - Titan Winch http://www.toyota-4runner.org/classi...ner-build.html
CAN-03runner is offline   Reply With QuoteReply With Quote
Old 02-01-2016, 02:26 PM #15
chitown40's Avatar
chitown40 chitown40 is offline
Real Name: Rob B.
chitown40 is on a distinguished road
chitown40's Avatar
Real Name: Rob B.
I think your noise is coming from the parking brake. If they are not adjusted correctly (and they normally aren't after you R & R the rear brake rotors. If they are loose they can clunk when backing up. I had to actually adjust the bellcranks on the parking brake after I replaced the rotor.
2009 GX470 Sport Edition w/ KDSS
chitown40 is offline   Reply With QuoteReply With Quote
Reverse Camera Install -- Need to wire to reverse switch tyrenta 3rd gen T4Rs 2 07-14-2017 02:56 PM
2000 limited, clunking in drive and reverse mtyink 3rd gen T4Rs 6 07-31-2014 01:32 PM
2007 cyclical clunking in reverse Monel 4th Gen T4Rs 2 06-12-2014 06:33 PM
Knocking / Clunking in reverse deziner75 4th Gen T4Rs 1 07-23-2013 07:05 PM
Clunking in reverse when braking gqr1c3boi 4th Gen T4Rs 8 02-09-2012 10:09 AM
