Old 02-13-2024, 12:05 AM #1
kwhoadley kwhoadley is offline
Real Name: Kody
kwhoadley is on a distinguished road
Real Name: Kody
2007 4.7 power loss?
Greetings team. Long time member, 4th 4Runner (1997, 2004, 2017, 2007).
Just purchased the below a few weeks ago. All maintenance below was done to get a baseline. I’m not new to working on vehicles, but am by no means an expert.
Vehicle: 2007 4.7 4wd 146000 miles
Maintenance this past weekend. All fluid weight (amsoil used) and spark plugs per manufacturer recommendations. Spark plugs bought from local advanced auto.
Saturday
- front and rear differential drain and fill
- transfer case drain and fill
- engine oil drain and fill
(All straightforward, no issues)
- transmission drain and fill: messed up temp check procedure but fixed prior to driving (forgot to ensure vehicle was on when in temp range)
Sunday
- spark plugs changed (didn’t check gap but were supposed to be gauged, all coils “popped” on, double checked all vacuum lines secured)
- MAF cleaned (MAF cleaner used)
- throttle body cleaned (TB cleaner used. Didn’t remove, manually moved butterfly)
- removed the top layer filter in engine air filter housing (can’t remember name)
- disconnected battery for about 5 minutes once complete
- Upon initial start after Sunday maintenance, car cranked for several seconds and didn’t start. Cranked again and started. No starting issues since.
- Very high idle initially, ~1800-2000. Normal from what I can gather. Idle worked its way down since and is in normal operating range. - - - Engine sounds fine (minus the whine from a tensioner pulley or alternator, will change that in the coming weeks), no knocking/ misfire, etc.
- Monitoring gas mileage but no noticeable change.
Problem: Not sure if it’s in my head but the vehicle just doesn’t seem to have any power now. It feels slow, not as responsive, and doesn’t seem to have the same low end torque.
- How long does it take for the computer to reset?
- Anything I could have missed/ messed up? If “problem” is still present this weekend I guess I’ll pull the plugs and verify the gap.
I don’t remember this being an issue on my 04’ when I did the same exact reset maintenance.
Thanks for your time and input.
Kody
2007 Silver Limited 4.7: Bilatein 5100 front and rear, 1.25?; Moog FJ springs front and rear; Nitto Grapplers 265/70/17;
2018 Super White ORP: Bilstein 5100s front and rear, .85; BFG Ko2 265/70/17/C (sold)😩
2003 Grey Sport Edition V8 (sold)
1997 Bronze 5-speed manual (sold)
kwhoadley is offline   Reply With QuoteReply With Quote
Old 02-13-2024, 07:28 PM #2
inscarguy's Avatar
inscarguy inscarguy is offline
Real Name: brian
inscarguy has a spectacular aura about inscarguy has a spectacular aura about
inscarguy's Avatar
Real Name: brian
Your Sunday stuff is normal when the computer is reset. It won't take long for the computer to relearn. Drive it like you stole it so it will remember those parameters.
Double check the vacuum lines especially the one that runs under the intake manifold on the rt front corner. I would change the PCV valve. I didn't see it on your list of changed parts. I would just bet on it not being changed prior.
Also go onto toyota's website, go under the "owners" tab and enter your vin. It will give you any work done by toyota since new. It's not necessary but sometimes it's interesting what's been done.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
inscarguy is offline   Reply With QuoteReply With Quote
Old 02-13-2024, 08:14 PM #3
Real Name: Kody
Real Name: Kody
Thanks inscarguy. PCV is waiting at the dealer for me to pick up, just haven’t had time. Good call on the Toyota website.
My buddy said the same thing about vacuum lines, so I’ll be checking those for a third time. Going to be real upset with myself if I missed one of them twice.
I’ve been driving it a little harder than normal, so I’ll keep that up until this weekend and reassess from there.
drain , fill , maintenance , plugs , vehicle
Loss of power, no CEL rjb75 4th Gen T4Rs 5 07-02-2020 03:49 PM
Please Help: Extreme Loss of Power (@ 30% full power) mattkc16 5th gen T4Rs 33 05-17-2017 09:43 PM
loss of power t4rFL 3rd gen T4Rs 5 07-02-2016 07:11 PM
power loss when in 4x4 Challenger44 3rd gen T4Rs 11 03-03-2015 06:05 PM
how much power loss am i looking at? 99NWA4R Engines / Suspension / Wheels / Tires / Audio / Accessories 19 10-26-2010 08:12 AM
