Old 02-16-2024, 08:34 AM #1
parsky1 parsky1 is offline
parsky1 is on a distinguished road
Transfer case rear driveshaft seal leak
I just serviced all the 4wd fluids and switched to Redline 75w-90. 190k. I noticed a hanging drip of fluid at the rear output of the transfer case to the drive shaft. Should I just replace the seal? I’ve heard before that replacing the seal is just a bandaid because usually a worn out bushing causes too much play and that wears out the seal. Thanks.
This is the best video I could find but it’s not a 4th gen…. Anyone know of a better one?
DIY: Toyota 4x4 Transfer Case Rear Flange Oil Seal Replacement - YouTube
parsky1 is offline   Reply With QuoteReply With Quote
Old 02-17-2024, 12:00 AM #2
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
Replacing the seal can be a temporary fix if the underlying cause isn't addressed. Make sure you take a good look at the bushing for any signs of wear and play. If it's showing some serious wear, it's probably a good idea to change both the bushing and the seal. That way, you can really sort things out and avoid having the same problems pop up again.
weberlukas74 is offline   Reply With QuoteReply With Quote
Old 02-17-2024, 01:24 AM #3
Rocket3004 Rocket3004 is offline
Rocket3004 is on a distinguished road
Here is a good video from a similar car from one of the forum members @mtbtim . Remember not to scratch the sealing surfaces of the seals. I can't comment on the bushing wear though.
Transfer Case Output Shaft Seal Replacement - YouTube
Rocket3004 is offline   Reply With QuoteReply With Quote
bushing , case , rear , seal , transfer
Transfer Case output shaft seal leak Matt831 5th gen T4Rs 4 08-23-2021 09:50 AM
Transfer Case Leak -- Output Shaft Seal Merle Maintenance/Detailing 3 04-17-2017 12:32 PM
This transfer case seal leak mumbojumbo has me shaking in my boots. JEL 4th Gen T4Rs 12 05-27-2014 05:22 PM
Leak from transfer case to driveshaft. Zuke 4th Gen T4Rs 7 05-23-2011 02:44 PM
