02-15-2024, 03:08 PM
Can you identify this elbow?
So, my cooling fan exploded at really high RPMs, and broke a bunch of crap: blew a hole in the side of the battery, tore up fan shroud, blew off plastic elbow connected to steering pump reservoir, shattered part of the plastic cover that goes over the intake, dented the hood, tore a hole in a vacuum (I think?) Hose, cracked said hoses' elbow, not to mention a COMPLETELY eviscerated fan.
I was pretty impressed at how much damage it caused, to say the least. Fan clutch was seized, so when I floored it in a moment of panic, the fan decided to unalive itself and tried to take out as much as it could in the process.
Anyway, I'm having trouble identifying this elbow pictured below, can anyone help?
02-16-2024, 10:21 AM
i could not find anything on the diagram , even on the epc diagram for air cleaner.
if your area don't do any smog check, consider an air intake from AFE, the TRD use that design, or try a junk yard and swap it out, maybe a home depot ?
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
02-19-2024, 08:40 AM
Real Name: brian
Real Name: brian
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
02-20-2024, 06:44 PM
Originally Posted by inscarguy
Dang. I had a feeling it was a part of the housing. Since I can't afford a new intake right now, looks like it's the junkyard or JB plastic weld that will have to suffice for now.
Thanks guys!
02-22-2024, 11:10 AM
you might be able to find a used intake on ebay.
