Old 02-19-2024, 03:00 PM #1
fAdrianne fAdrianne is offline
fAdrianne is on a distinguished road
ABS Actuator
Hello! I have a 2003 4Runner with 240K miles. 2 wheel drive. Recently, the emergency brake light lit up along with a constant beep.
The mechanic that I have gone to for quite some time only ran the codes it was throwing, and said I need to spend $3K on a new ABS Actuator. Everything I have read online says that when this fix was done, the problem happened again after a few weeks. Is it possible that the sensors are dirty or bad? Or possibly out of brake fluid?
The mechanic did not tell me if any of this was checked and said he was not willing to troubleshoot the issue. Very disappointing as I have been going there for 5 years. Having it towed to a new mechanic tomorrow who seems more willing to troubleshoot.
Any suggestions or experience with this issue?
fAdrianne is offline   Reply With QuoteReply With Quote
Old 02-19-2024, 07:35 PM #2
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
Firstly, take a peek at the sensors for any dirt or damage, like you mentioned. Additionally, ensure the wheel speed sensor rings are intact and free from debris.
Next, examine the brake fluid level and condition. Low brake fluid or contaminated fluid can trigger ABS warnings. Check for any leaks in the brake system as well.
Considering the mileage, it might also be prudent to inspect the overall condition of the brake system components, such as the master cylinder and brake lines.
Also, don't overlook the electrical connections tied to the ABS. Loose or corroded connections might be giving you false readings.
The ABS pump motor relay could be causing trouble. Test and inspect the relay for any signs of wear or malfunction.
weberlukas74 is offline   Reply With QuoteReply With Quote
Old 02-20-2024, 12:27 AM #3
SocalSam SocalSam is offline
SocalSam will become famous soon enough
How is braking action and pedal pressure? Is system holding brake fluid? Are there any noises from the booster unit? Loud screech is bad pump motor. Constant pump running and sighing sound is leaking accumulator. There is also a pressure sensor that can go bad.
This is my 4Runner:
2003 Toyota 4Runner Brake Booster Noise C1223 and C1252 - YouTube
Replaced pump/accumulator with a junkyard example from '04 GS300 for $50.
SocalSam is offline   Reply With QuoteReply With Quote
abs , actuator , issue , mechanic , troubleshoot
Door Actuator or Fob Issue? (One Actuator Already Replaced) Mlynn 4th Gen T4Rs 6 06-28-2022 12:02 PM
Preventative maintenance for front diff actuator and/or center diff lock actuator NJ-4Runner 3rd gen T4Rs 12 04-22-2021 11:26 PM
4th Gen Actuator, Help! SHagood 4th Gen T4Rs 11 01-22-2020 11:08 AM
Can't ind actuator lonewolf98765 Classic T4Rs 15 12-09-2013 09:30 AM
4Lo actuator faqoldschool 4th Gen T4Rs 6 09-23-2012 12:12 AM
