Old 02-20-2024, 05:10 PM #1
happy camper happy camper is offline
happy camper is an unknown quantity at this point
4th Gen CV Axles interchangeability with 5th Gen?
2007 4Runner Sport 4WD, 340,000 miles
Both of my front inside boots are seperated so its time to replace. I had made the mistake of replacing Toyota axle assemblies with aftermarket (OReillys with lifetime warranty). I want to go back to the Toyota axle assemblies.
Checking with Olathe Toyota parts center, 43430-60062 is the latest, and correct, axle assembly per my VIN. Shaft Assembly Front Drive 43430-60062 | Toyota Parts Center
Also, with this latest part number, Toyota requires a new lock nut hwhich happen to be on back order along with unicorns. Nut Lock 90177-28001 | Toyota Parts Center
However, I have seen discussions of guys using the 5th gen axle assemblies in the 4th gens (bolt right in). Reasons why are improved boots and cheaper. Does anyone have any direct experience using the 5th gens in 4th gens?
Thank you and any guidance and direction is much appreciated.
happy camper is offline   Reply With QuoteReply With Quote
Old 02-21-2024, 08:45 AM #2
slixx1320 slixx1320 is offline
slixx1320 is on a distinguished road
I've read they're compatible. Personally, I've never had to do it so I can't tell you first hand. Why not look into reman axles? I don't know if there's any in stock but call them up and see if they have any available.
https://parts.lakelandtoyota.com/p/_...306008284.html
slixx1320 is offline   Reply With QuoteReply With Quote
Old 02-22-2024, 02:37 PM #3
jmp55 jmp55 is offline
jmp55 is on a distinguished road
Yeap, they work no problem.
I swapped both of my CV Axles with 5th gen part in summer of 2022. No problem so far.
Part Number Part Name Price Quantity Total
43430-60082 CV Axle (Left, Right, Front) $311.03 2 $622.06
90178-28002 Nut Flange $3.84 2 $7.68
95381-04045 Pin Cotter $1.25 2 $2.50
43514-28010 Wheel Bearing Dust Cap (Left, Right, Front) $20.09 2 $40.18
95381-03225 Lower Ball Joint Cotter Pin $1.25 2 $2.50
90171-14042 Outer Tie Rod Castle Nut $3.60 2 $7.20
Ordered from TRDshop.com
2009 Black T4R Sport Edition V6 4x4
jmp55 is offline   Reply With QuoteReply With Quote
Old 03-03-2024, 03:01 PM #4
MountainBiker MountainBiker is offline
MountainBiker is on a distinguished road
Yes! 5th gen CV axles fit 2006 V6
About 10k miles ago I installed OE 5th gen CV axles (43430-60082) with OE diff seals (use 2” PVC cap to hammer in), and National 710573 wheel bearing seals (use hub cap to hammer in).
5th gen CV axles are reputed to have better boots, but otherwise similar or same as 4th gen axles.
2000 Limited: Toytec Superflex, 255/85-16, Lil Skips gas tank skid, SaVage rear bumper and skids, BAMF Sliders
2006 SR5: FJC Coilovers +2", Toytec Superflex, 255/85-16
Sold: 2017 TRD OffRoad Prem (this rig was too nice for me!)
MountainBiker is offline   Reply With QuoteReply With Quote
Old 03-05-2024, 09:56 PM #5
Jubsz Jubsz is offline
Jubsz is on a distinguished road
I changed both my front axles with remans last week. I did passenger first, thinking it was the only one I needed and noticed the driver was bad when I was under there. After the first time I did the passenger, the diff seal was leaking. I definitely recommend replacing that but be careful doing so.
I'd also recommend buying OEM knuckle seals along with both axle/diff seals. Be careful putting them in. I changed out that passenger one 3 times due to putting it in too far and one time slightly crooked. The lip of the seal will protrude from the diff housing if done correctly. I also stopped using the seal driver for diff seals, did it mostly by hand, and used a punch to even it out and finally get them set. No more leaks after a week but it annoyed TF out of me to pull that passenger axle basically 4 times in a week. I did use the seal driver for knuckle seals.
This thread helped me to get it right - 3rd time replacing leaky front axle seal with OEM. Why does it keep leaking ? | IH8MUD Forum
The Reman axles are very low in inventory. I called many places and dealers told me I could only order one if I came in. I went in person to my local dealership parts people that are familiar with me and they were able to order two from New York. IIRC, they said 5 total remained.
This thread has the process and some good info:
CV Replacement Tutorial with New Seals (120+ Pictures)
Jubsz is offline   Reply With QuoteReply With Quote
Old 03-07-2024, 11:56 AM #6
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
dropping to confirm that I'm on fresh OEM from toyota 5th gen axles in my 4th gen with no issues (other than having to change to the new style nut since the newer axles do not have the hole for the cotter pin).
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
aemravan is offline   Reply With QuoteReply With Quote
4th , assemblies , axle , gen , toyota
Parts interchangeability SurferUK 4th Gen T4Rs 3 06-26-2021 01:11 PM
Parts interchangeability Adamdmc 3rd gen T4Rs 4 03-22-2020 08:43 PM
T-case interchangeability zoombyu86 3rd gen T4Rs 7 04-17-2017 07:39 PM
o2 Sensor Interchangeability 4runn4r 3rd gen T4Rs 9 04-01-2015 06:43 PM
4x4 indicator switch interchangeability Diagram14 3rd gen T4Rs 0 09-01-2010 12:16 AM
