Old 04-21-2024, 03:20 PM #1
Buckaroo's Avatar
Buckaroo Buckaroo is offline
Buckaroo will become famous soon enough
Buckaroo's Avatar
CV Axle Removal - Slide Hammer Fork Adapter
I am going to buy a CV Axle Removal Fork for my slide hammer. I think the ones that are 48mm wide are not big enough for the T4R (OTC 7507 or CTA 4245). I think I need a wider opening like the CTA 1040 (63.5mm). Might still not be wide enough. Can anyone confirm?
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
Buckaroo is offline   Reply With QuoteReply With Quote
Old 04-22-2024, 12:55 AM #2
bob3dsf's Avatar
bob3dsf bob3dsf is offline
Real Name: Bob
bob3dsf will become famous soon enough
bob3dsf's Avatar
Real Name: Bob
Have no idea, but I can confirm you don't need that to get the axle out. You can pry where the axle meets the diff with a pry bar, just watch the dust shield. You can use a BFH and a drift on the flat spots on the inner housing. That's what they are there for. If you go the hammer method, don't take huge swings, just solid, quick taps while keeping pressure/pushing the drift (or a cold chisel). Big pounding hits will just cause it to bounce back . It also helps to have a helper hold the outer end so the axle is roughly level, or tie it up with a bungee or something. The weight of the unsupported, outer end pulling the axle down just contributes to the inner shaft and C-ring binding.
2008 SR5 4WD
bob3dsf is offline   Reply With QuoteReply With Quote
Old 04-22-2024, 07:52 AM #3
Buckaroo's Avatar
Buckaroo's Avatar
Thanks - I have removed and installed a few CV joint axles in the past and understand the drill. In my younger days, I didn't have the money to buy specialty tools but now have a few dollars so don't mind spending a little bit to make things easier in my old age- the fork attachment I just bought was $25 and will be here today. That said, still don't have a lift,
2004 Honda Accord
Old 04-22-2024, 08:10 AM #4
daprotege5 daprotege5 is offline
daprotege5 will become famous soon enough daprotege5 will become famous soon enough
axle forks work great as well, and are pretty cheap.
daprotege5 is offline   Reply With QuoteReply With Quote
Old 04-22-2024, 09:38 AM #5
Buckaroo's Avatar
Buckaroo's Avatar
Thanks - I did look at them and if I didn't already have the slide hammer, I might have gone that way. I am just replacing the seal and am planning on reusing the CV Axle so I am trying not to beat it up trying to get it out. I want to avoid bending up that light sheet metal shielding around the shaft next to the diff that @bob3dsf pointed out.
2004 Honda Accord
Old 04-22-2024, 08:45 PM #6
when i was swapping the axles out with new ones, pry bar and everyone elses just hit with a hammer was scratching them up pretty bad. got the forks in and literally slide it in, couple taps of the hammer and bam axles pop right out, so their definitely simple and worth the bucks. everybody has their preferences thought, both handle the job easily.
Old 04-23-2024, 07:24 AM #7
parsky1 parsky1 is offline
parsky1 is on a distinguished road
Which did you end up buying and how did it work out?
parsky1 is offline   Reply With QuoteReply With Quote
Old 04-23-2024, 02:18 PM #8
Buckaroo's Avatar
Buckaroo's Avatar
I bought the CTA 1040 Large Adapter for my 5 lb OTC slide hammer. It has a 63mm wide opening which wasn't wide enough to slip over the CV Axle inboard hub (which does differ by manufacturer). I ground it out to 67.5mm wide and it could get a marginal grip on it but I did not have enough oomph to break it free. Maybe if I had an extension for the slide hammer to get more travel on the weight, it would have worked but at that point I was done (and a little pissed). So....I did it the old fashioned way - used my pry bar on the back side and a 3 lb sledge, gave it a couple of good whacks and it came free and avoided bending up the sheet metal shield. So someday, if I live long enough, I may find a more elegant method of removing CV Axles....maybe I will try the forks next time!
2004 Honda Accord
axle , cta , fork , hammer , wide
PLEASE HELP Rear Axle Shaft won't slide back in after bearing replacement HELP! hungryeddy 3rd gen T4Rs 15 08-29-2022 10:13 PM
3rd Row Half Removal Cargo Fridge Slide - 6 Seater T4R wild_turkey 5th gen T4Rs 12 01-18-2021 10:53 PM
Goose Gear Plate System Install - with cargo slide removal Fergie 5th gen T4Rs 11 04-20-2018 09:21 AM
Urgent help! axle wont slide in! gapboi210 3rd gen T4Rs 1 10-27-2006 01:29 AM
