Originally Posted by SurferUK
Have you jacked it up and tried to rock each wheel?
It does sound like a wheel bearing, if it was the diff I wouldn't expect the neutral test to make the noise stop, although I suppose it could, but at the least the tone of the noise should change as everything that part of the drive-line would be rotating freely.
What's your diff oil age and level?
Yup, last weekend had the rear end in the air, took both wheels and brake calipers off to only hear the drive line. Either side felt solid, no back / forth or up and down movement on either side and when I spun it by hand it felt OK.
I am pretty sure I can feel the noise lessen when turning right and def no change in noise when throwing it into neutral.
Diff oil I have replaced recently, however the PO hard to say. The PO is a coworker of mine who had the car since it was brand new, but he is not very mechanically inclined and does not remember if the diff fluid has ever been replaced. I will say when I drained it was black and stank to high heaven, however the fluid level was spot on, when I removed the fill plug a small amount started coming out. I have to assume it was never replaced and has 180K on it. I cannot complain too much though, coworker sold me the 4Runner for $500 so I know I will have to do some fixing.
